i would say give it a try, and i have manage to remove all bloatware in the metro folder and apps folder by using the latest root explorer 2.16...
So far so good.. Runs great.. Had the issue with the data but got that knocked out by setting the APN.. Big switch from cm7 though but i knew that.. I'll be going back prob in a few days..
Gonna play with this for a few days to get it all set up to nandroid it.. Speaking of which, one of the major things I miss so far from cm7 is the notification bar widget.. Would you by chance know where to get it from if its even possible.. I googled around but no luck..Had to try itSo far so good.. Runs great.. Had the issue with the data but got that knocked out by setting the APN.. Big switch from cm7 though but i knew that.. I'll be going back prob in a few days..
I just donated 10.00 via paypal for you- thanks for the good work. I have not made the leap yet cause the camera is too important to me; if you get it working I will donate another 10.Well, I don't think Huawei would ever release Android 2.3 on the Ascend. So, I took it upon myself to try and get it on there. I'm currently releasing builds (should be beta stage, now) of CM7 (Android 2.3.4).
If you'd like to go ahead and try it out, please visit my wiki here: CM7-Ascend - Prepaid Android
Please remember that I do this in my spare time. I don't even use the Ascend anymore, so I can't say it's really a big priority for me. However, I'd like to get all the kinks worked out. If you do link this somewhere else, all I ask is you provide proper credits. Thanks for looking.
Screenshots are available on the wiki page.
isaacj87
P.S. If you like what I'm doing (and you want me to be able to continue), please Donate! Any and all donations are appreciated: Donation Link!
The camera and videocam are now working in CM7-Ascend. Bar-code scanners still wont work with it tho.I just donated 10.00 via paypal for you- thanks for the good work. I have not made the leap yet cause the camera is too important to me; if you get it working I will donate another 10.
The reason I donated is I saw people advertising on craigslist to do this flash for 25.00. I think you should get the money since it is your work.
hi. i just wanted to kno if it is ever possible to get flash up without the extra browser from the market . i kno flash needs arm7 and 1ghz processing power but is it possible to work around it. just a curious noob![]()
Anyone know a good place to get cm7 themes that work on the Ascend? I'd also like some suggestions if you got em.![]()
I tried sending pics from my email which usually works
Cyan and black top to bottom.
I'm running Cyanbread theme from Theme Chooser, ADW home launcher with Antique CM for custom icons, Cyanbread X for custom wallpaper, and Wigitzoid for custom Widgets..Cyan and black top to bottom.
Ooooh, shiney.
Well actually, I can receive things from certain carriers, I'm having trouble receiving things from boostmobilei you sending pictures with your wi-fi on or off?
I am at work but when I get home I will see if I can post it up here for you.
But if you really want to save time, chances are if your oc'd to 710 on the 0521 build you would have no problem at 748. Isaac tweaked the oc kernal on the new build so this is more accurate than the previous build. So long story short oc'd at 710 on this build is faster than 748 on the 0509 build.![]()
I've setup my extra laptop to build Android. This means I'll do periodic builds of CM7-Ascend. There's only one thing: I'm not going to work on it. Unless there's super easy fix that can be implemented, all I'll do is sync with CM7 repos to keep it up-to-date. I'm not doing anymore kernel work or ROM fixes.
There will be some new instructions to install new builds of CM7. Nothing crazy, but I'm not going to work on the wiki anymore since all I'm doing is keeping it updated with CM. Since Koush seems to ignore anyone not directly involved in the CM project, I'll have to keep CWM updated. New builds will be ROM Manager only.
Happy Ascending.
P.S. My github is still up. If someone has code fixes for just do a pull request and I'll review the patch and merge.
P.S.S. I rarely ever check forums anymore, so don't expect any responses from me.
Well, I guess I spoke too soon.
Just did a test build and tried it out on a buddy's phone. I don't know what happened between 05/21/11 and now, but most important things are broken. WIFI doesn't work, no service anymore, and screen rotation doesn't work, overclocking is forced now.
Maybe I just missed something (which I don't think I did), but things aren't looking good. It was one thing to work on a phone that I didn't use, it's another to work on one I don't own anymore.
Ouch, but honestly you are like super ascend genious..so i have no doubts you will be able to get it running as well as CM6 if not better.
