yes!!new build will be ready sometime today/night.
Sorry folks for the tease and then such a long delay. I lost power the day I posted and said I would have it uploaded and then had to go out of town. Will be uploading it soon and will post links to changelog and downloads here in a bit.
Added:
- Custom bootanimation
- Added files & edits so bootsound works
- Added DT's apps2sd (sdcard will need partition to work correctly
- New boot splash.
- This is build is based on isaac's 05212011 build
- Has the 748Mhz oc'd kernel and new governors.
- New Cyan Theme added.
is the wifi issue fixed on this version?
Exactly, just whats listed on the changelog is all thats changed. I will look into the mac address issue tho for the next build.Since this build by PG is build off the last build by IssacJ87 I do not think that the wifi issue with the NIC MAC addressing has been fixed. I think that PG would have posted that in the change log if it was modified.
well im back to 52111 since this one wont work for me
fixedSweet! Will check it out in a few hours.. On a side note and not at all trying to be nitpicky, just noticed on the wiki it says newest build is 0608 instead of 0618.. threw me for a second
were you able to run the 05212011 build?well im back to 52111 since this one wont work for me
well now i restored and im stuck on loading screen when turned on so wowfixed
yes i reflashed and yes i got the newer version of gapps as wellMay be the newer OC'ed kernel.. I know some people were having issues with it when they tried it before.. Did you try a reflash? And the newer version of gapps? I'm crossing my fingers..
u tried the older version of gapps? I've heard of issues with the newest.yes i reflashed and yes i got the newer version of gapps as well
no i havent i will try that then..u tried the older version of gapps? I've heard of issues with the newest.
