Hello again,
Well, I FINALLY got CM7 but lost a bit of my buzz when I realized Swype was gone. I literally can't stand tapping in things manually, considering my thumbs are quite large and always choose the wrong letters.
So, I've been looking up alternate ways to install Swype, and this is what happened:
-Installing the Beta from the official Swype website: Made my account, logged in, went to download the Beta and it gave me a parsing error every time.
- Installing the .zip file of Swype: I copied the Swype .zip file to my SD card, booted my phone into CWM and tried to install the thing from there. Trouble is, the operation would just abort.
- Installing a user-made file: Someone over at XDA Developers made a way to install Swype without all of the extraneous BS. Turns out, this method is extraneous BS. I downloaded his .zip file, got Root Explorer, found that "data/local/" file, copied it into that, pressed "execute," and all I got for my trouble was "not a tty" on a black screen.
There was a source code attached that I then ran in Terminal Emulator:
After granting SU permissions, I tapped in his code:
adb push swype-installer.sh /data/local/
All it said was "adb: not found."
So after all of these attempts, I'm going to assume it's impossible to get Swype on a CM7 modded device. That being said, does anyone know of an alternative way to do this, or of any other keyboard programs in the same vein as Swype I could install?
Thanks.
