PlayfulGod
Extreme Android User
you can use any launcher u want lol, same goes for bootanimations n sounds
um where can i get a link for that? lolu tried the older version of gapps? I've heard of issues with the newest.
ok thanks lol
still didnt work :/u tried the older version of gapps? I've heard of issues with the newest.
still didnt work :/
yeah well im just reflashing over and over ill see what happens...May have to do the full wipe and start fresh.. Maybe even flash to stock then start with cm7 fresh.. Still have a few hours before I can test it out..
finally it works!![]()
Ok i hope i can help had the same issues gor the people with the gapps issues boot into your clockwork and do an install from zip and instead of choosing your rom just choose the gapps zip just put the whole zip on ur sd card.
For those stuck on the ascend screen and had tried to install it over and over when it gets stuck unplug your power pull your battery for like 5 minutes boot it up and it will finish the install this worked for me.
thankscongrats!!!
Dont ever set at boot til u know your phone works with a settingi tried to clock mine @ 748 & govern Smart A$$. but my phone kept rebooting. so i manage to set it down @ 710 running smoothly. funny every time it was rebooting i had like 5 seconds to go in settings & change it... thought i had to reflash back & start all over again. lol...
Dont ever set at boot til u know your phone works with a setting![]()
so set on boot does that restore what you set it on everyime you reboot or does that put it back to 600 every time if you check it.
and if it bootloops u have to boot into CWM and wipe data to get it to boot again.What you select.. So if you pick 748 and have that set it will go to 748 on reboot..
First, if you want the stock 2.2, you'll need to flash back to stock 2.1, then run the 2.2 update.
Second, are you saying PlayfulGod's CM7 update is bad SOLELY because he added a different launcher and because you didn't like the boot animation? That's pretty harsh criticism for cosmetic additions, additions you can easily change, at that.
