what version of Amon Ra is it?
I assume 2.3, I got it from the link in the guide.
I didn't extract it at all. It is the same size before and after renaming.
I thought I was supposed to rename 'PC36IMG RA 2.3.zip" to 'PC36IMG'?
Should I rename it to 'PC36IMG.ZIP'
this is what it should look like![]()
if you see the file is still zipped
hmm i see so it was'nt a zip file. at least in the end you got it to work =]
cant get beta key to work, and have repeated the steps several times....
Hey guys. I've rooted once in the past and managed without too much trouble. I read the OP's guide in its entirety and I think I get it, but when I get to the Revolutionary page (after downloading the file) there is no option for the 4G. I checked each to see if there were any that worked with 2.16, but didn't see any. Am I missing something? :-S
Are you sure you're using the right version?
The EVO 4G supersonic 2.16 hboot is in the latest version.
Hi Friends:
My Evo 4g has S-off but but I couldn't run the steps 8,9,10,11,12 and 13....two questions:
1. Do I need to download and flash ClockworkMod Recovery?
2. How do I run the steps 8,9,10,11,12 and 13?
Thanks
TecMan
i did the volume down deal and my evo is hboot 2.160001, ive tried to get several new keys ive copy pasted them ive typed them, ive deleted everything and started over fresh, my evo is a assurion replacement phone would that matter? cant get revolutionary to validate the beta key.
Hi Friends:
Thanks
TecMan
yes i work!!!!!!! doing some of it now. well sort of.I know you can't take a nand from one phone and use it on another but can I take my app backup from one Evo made on TB and use it on another Evo?
On a side note Ocean, do you work? You are all over here. Oh and what happened to Matlock?
