In step 3 above, what is the difference/consequence of choosing a 1024 vs. 2048 size for ext2??
THANKS!!
So...um...yeah...I just tried to boot into recovery and partition my card using Clockwork and did NOT see the options above. If I go to the "Advanced" menu in Recovery and chose "Partition SD Card" the
only options I have are:
128M
256M
512M
1024M
That is right off the bat...NO options like in the instructions above.
I chose "1024M" and the next screen allows me to select "Swap Size" of the recommended 32M.
My
ASSumption is that Clockwork only allows you a 1024M partition?? I'm gonna go to Amon RA and I'll be I'll get the options mentioned in the Guide above....
EDIT: I'm leaving the above information in case someone else finds what I found...but I went to ROM Manager and chose the "alternate recovery" method to flash Amon RA. Booted again into recovery and ALL the options in the Guide for partitioning were available.
Something else I noticed brings up another question....the suggestion size of the partition is either 1024 or 2048 but I noticed that one can choose a LARGER partition. Besides larger partitions being overkill or becoming ridiculous, is there a limitation with any of the apps2sd options that "caps" the partition to 2048?? Just wondering...
