andygu3
Android Expert
I probably should move this to rooting for dummies but......if you want ocnbrze, go ahead
Yep, all of those are turned off and/or uninstalled.
Yep, debugging on. Don't have her phone right but I will try toggling the debugging. Should I do that after it accepts the beta key?
Then should I try disk drive before or after debugging toggling?
No, I have not tried a different computer, I do not have access to another one that's not mine
When I rooted my Evo, I never was able to use Unrevoked. I used the Auto-Root script from xhause and rooted on the first try.
The only thing I did differently with my Evo was that I ran the RUU prior to running the script and that seem to get the correct drivers installed. I'm trying to avoid completely wiping her phone so I can use TB to back up some app data before I wipe.
But if I have to run a RUU and it doesn't work, I'll be pissed but........to find root will far out way not having certain data saved.
Oh well, I've tried everything I can think of.
Anyone have an official RUU I can run, thanks
