yes that is corect. you will not be able to flash most things because of that.Hello...
Wanted to clarify a couple things you mentioned in your response...
So if "most files" are using amend then the limitation is the fact that Clockwork uses edify, correct??
no you are not correct. nandroids are specific to recovery. so clockwork mod nandroids will only work with clockwork mod. but, a clockwork mod 2.6 nandroid will work with clockwork mod 3+. but never with amon ra.And to clarify this/state it another way...Clockwork 2.6 and Amon RA 2.3 will BOTH work with BOTH scripts (edify and amend)?? Does that mean that a nandroid backup created with Clockwork 2.6 can be restored by Amon RA 2.3 and vice versa...or am I understanding/presuming something incorrectly??
The reason I'm asking the latter question is because when I flashed Mik 2.52 a couple days ago with partitioning and pre-wipe using Amon RA as recommended (using Amon RA recovery for the first time) I could SWEAR that I was experimenting a bit while booted up in Amon RA recovery and tried to open an previous CLOCKWORK nandroid file and Amon RA would NOT READ the file. Thinking back, I THOUGHT I was on Clockwork 2.6 when I created the pre-Amon RA nandroids but it is LIKELY that I was on 2.5.x...which would explain why Amon RA would not read those nandroid (if I understand the "both script compatibility" issue correctly, right??
i wish that they were interchangeable but they are not. amon ra nand's only work with amon ra. so it is no wonder that it did not work when you tried to restore the other's nandroid. and it has nothing to do with script compatibility.
