Cyanogen (what is this and will this make my evo faster?)
or you can flash cyanogen mod (cm7) cm7 is a great rom. it is an aosp (android open source project). it is a rom without sense installed. it is very fast but does need a lot of tweeking.
i always root just to get the free wifi teather
i dont get into all the other stuff lol .. thanks
i tried downloading the wifi teather and it didnt work. it says my phone isnt rooted ima downloaded that a c what happens
settings/ app/ ?
is it evo (zysploit?)
wow gotta get use to the new rom it looks cool
and now i see the superuser
okay, on android 2.2, i had rooted it using unrevokedforever, then i upgraded using the 2.3.4 OTA update from sprint, which took away my super user, and everything, but my s-off remaind well s-off.... so how in this world, considering i didnt flash any rrecovery images or i didnt back anything up, am i supposed to get my phone rooted again???
Ocn, I forgot to ask this question yesterday, but after getting all rooted and what not, do you have to do the Update Profile and/or Update PRL?
Ocn, I forgot to ask this question yesterday, but after getting all rooted and what not, do you have to do the Update Profile and/or Update PRL? I know not to take a OTA update from what I have read and from what you posted above. But once I am on Mik3d, probably won't want to go back to anything else lol.
Yes updating your profile and prl is just fine. See this post with some info about what that does.
Thanks Nick for the information. Now that I know that and hopefully have everything... I think it time to try this rooting out.... Of course if something happens that isn't right... will be back here to see if can get a solution to the problem..
Well... Have successfully got root and have put ra on... doing backup now.... Hopefully when backup is done... can get back into phone without the '!' showing up.... then it's time to get titanium and do a complete backup, then as you all say... time to get my flash on
Edit: Didn't copy over PC36IMG_RA-2.3.zip so RA didn't get put on... Now can I copy that over, rename to pc36img.zip then let the thing run it? Or how does that work?
You are talking about getting your recovery right? If so yes, that's what you do.
Yeah, I got clockwork on there but wanted to put the one ocn was talking about, the amon? one is it called... So I just copy and rename that file, then go into hboot and let it do it's thing... then remove the file....
That is correct.
Good... Now got the correct recovery on there... re-did the recovery... now to do a titanium backup and then put mik3d on then put on golden monkey.... then get into setcpu.... so far so good... no glitches what so ever....
Edit: Can I now turn off the USB Debugging? as so far I haven't seen any mention of it except to to it on to run the revolution stuff to get root...
