Well I went from being rooted to not rooted. I haven't done anything to my phone since the original root. My frustration level just went to 11. I have not installed any updates to Gingerbread due to what I was told when I had it flashed to Metro.
Hey new member here.
Im trying to root my EVO 4G and i have done well up to the point where i install the zip from my SD card. The installation was "aborted"??? What can i do? Wasnt found on SD?
Guys, I need some help here..
I have my card partitioned, and currently running on Supersonic 3D. Tried to copy some data to my computer, but I think that ROM has some problem in connecting to PC. So I insert my SD Card to my PC, but it couldn't opened and said that I need to format it. Pulled out, moved it back to my Evo. After restart, it seems that the phone will not read any applications on my SD Card.
What should I do? I am copying all my data to my PC now using USB Toggle on Recovery (I should have done that on the first place...). Thinking about formatting my SD Card after that.
Will it remove the Card Partition?
Thanks before.
Which Supersonic 3D are you running? There have been issues with usb connection to the computer. You may want to flash a different rom for now until the issues are fixed
Yes, I think I'm going back to Mik3D. I'm currently on Supersonic 3D Beta 1 Sensation XL.
So, if I format, will it remove the partition? or is there another way for my phone to read the applications on the partition?
Yea, the Supersonic 3D XL definitely has an issue
If you format, it will remove the partition. Why do you want to remove the partition? Or do you want to start with a clean slate because most of these newer sense 3.0,3.5 roms recommend that the sdcard be partitioned
No, I don't want to remove the partition. What I had in mind when my phone could not read the applications on SD Card is to restart with a clean state. Any other way so my phone can read again the SD Card partition?
So a2sd is working with the rom correct? After you flashed the rom, did you open up Terminal emulator and type
su
a2sd reinstall
If you did this, then did you happen to move your applications to the sdcard via manage applications?
I did that... I also had apps2sd, and everytime I install new applications it always asked if I wanted to move applications to SD Card. I'm not sure if it really works, because everytime I check my memory, both available memory (internal and a2sd) seemed to be reduced. But I thought that just how it worked...
Did I do something wrong??![]()
If you're using a2sd that comes with the rom and you typed a2sd reinstall, then those applications data would be moved to the partition. I would recommend not using apps2sd and not moving apps to the sdcard. If you still need space, have you moved cache to the sdcard? Type
su
a2sd cachesd
or
su
a2sd datasd
Rooting my evo... tried the xda process and found that my 2.3.3 Gingerbread needed something else. I think it was Gingerbreak that I used.
So I got to the point of downloading Clock<something or other> and my dumba** PDANet interrupted the download... and then something else happened... forget what. But the upshot was that I got s off but then the phone started installing the original zip from the xda rooting process. Prior to the Gingerbreak, the system wouldn't allow the install of the files from the zip but now *some* of them installed and some failed.
If I had deleted that file from the prior attempt, all would be fine.
And now my USB access to the phone is gone (pc can't see it), the phone can't get past the htc evo splash, and 'recovery' and erasing the storage both fail (in the bootloader menu or sub).
Gah. Hope I can recover my phone. I can get an micro card reader and delete that file and put anything else necessary on it for an install or other attempts to address my issues. The loss of USB support seems a significant issue.
Anyway, TIA for your help...
D'ohBoy
yes, but i would recommend amon ra 2.3 rather then clockwork mod. go to the guide and go to the switching recoveries section. use the intructions ther to get amon ra. after that you can go and get your flash on.Thanks for the suggestion... during the maintenance downtime this am for the forum I managed to get back to kinda running... have s-off but am running 2.2 (froyo?). I got a zip from another source on the web and dropped it onto the card. So I am wondering... can I get clockwork now and download me some roms or ? BTW, it was a happy moment when the phone came back
D'ohBoy
yes that is goodOh, yeah, my Hboot is 6.16.1002. Is that good?
D'ohBoy
I just rooted my Evo 4G for the first time ever. There were no problems at all along the way. Just follow the instructions, and it takes about 20 minutes. Thanks rEVO!
When i try to run revolutionary my computer says that it cant run because AdbWinApi.dll is missing from my computer. why is this happening? i have the dll file right here!!.. :\
