alright, i'll read EVERYTHING and try afterwards and let you know if i run into any issues!![]()
See post above.
Good luck and ask questions if needed.
i can't remember if this root thread is specifically for 2.3.3 software evo's righttt? ......
it is for gingerbread, yes. also you can double check by looking at your hboot or bootloader. so power off (you may need to uncheck fastboot in settings/apps) and then press and hold power+vol down. at the top of the screen is your hboot version.
if it is2.15 or 2.16 then use this guide
if it is 2.10 or less then use this guide:
http://androidforums.com/evo-4g-all-things-root/194918-rooting-dummies.html
You want to use this guide thennvm! i have 2.16 hboot
Do you have usb debuging turned on?should it take this long to look for my device :/ like it's taking ten mintues, should i just unplug my phone and redo it?
Type it into the doos box and hit enter. The program will then do its thing. When its done rooting it will ask if you want to install the recovery clock work select yesafter i find my new beta key, where do i put it.....
where is the DOS box? :/Type it into the doos box and hit enter. The program will then do its thing. When its done rooting it will ask if you want to install the recovery clock work select yes
When you run revolutionary and it gave you the sn for the phone that is the program or doss box that in talking about. when you get the beta key you then type or copy and paste into that and hit enter.where is the DOS box? :/
Maybe go here and read or print out the befor rooting and on to rooting sections so you can follow step by step.
http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html
Did you down load it and put it on the sd card?10.select recovery in bootloader.
11.select install .zip from sdcard.
12.find the superuser file and flash it.
i cant find step 12 :/
Did you do the part where it asked if you wanted to install recovery?
im there already but the su file isn't there. i think i messes this all up because i feel like theres no way i can put the file on now since i'm already so far into it. **** my lifeee :/Ok so you need to select recovery in the h boot screen where you are now Then you will see another set of options and you select flash zip from sd card then you should see files that are on the sd card find the su file and select it and yes to flash. You use the volume up and down to move and the power to select. after you flash the su file you can reboot.
In recovery there should be a option to mount unmount If you select mount then you can transfer the file now. You can also just reboot and put it on the sd card like normal. Then boot back into recovery by shutting the phone off and powering up with power and volume down like before and selecting recovery and flash zip .im there already but the su file isn't there. i think i messes this all up because i feel like theres no way i can put the file on now since i'm already so far into it. **** my lifeee :/
kkk let me do this now!In recovery there should be a option to mount unmount If you select mount then you can transfer the file now. You can also just reboot and put it on the sd card like normal. Then boot back into recovery by shutting the phone off and powering up with power and volume down like before and selecting recovery and flash zip .
