wishingtorooot
i can never power it back up, i've tried like five times ... /:
Did you select reboot from recovery
can you get back into recovery
I had that problem when i first was doing that and it was because the phone wasnt compleetely shut down. I wasnt waiting long enough. LOLi mean i'm talking about when you have to hit the power button and the volume down at the same time, i can never get it at the same time....sixth time doing it. but my phone comes on no problem it's just i cant get to the recovery because i'm and idiot and can't hit buttons
The way to make sure is to just pull the battery and put it back in.
I'm so frustrated! I finally downloaded MikG 2.59 and the next day 2.60, Ugh! Love MikG though. Tried More and Aggressive Kernels and I don't think my Evo likes either. Did battery calibration. I have SetCPU on Smartass. I've been getting 1X instead of 3G, DOUBLE UGH! Did the port and proxy 0's. The darn phone is harder to "dial in" then my dad's Top Fuel Dragster!
what also worked for me is to use notepad++. basically copy the beta key from the generator and paste it into notepad++ and then copy the key again in notepad. like frenchy said, then you go to the command window and click on the top left corner to bring the drop down window, select edit, then select paste. it actually took me 4-5 times before it worked. not sure why it does that for some people. but keep trying. it is frustrating, i know. keep us posted.
I would like to put my two cents in here. What i notice about this is that when this happens is because one they took the page off, minimize it or change tabs. Dunno why, but it does. It works best while typing in the cmd and having the revolutionary page in the background.
yeah i have even tried that when i had my issue that did not work for me. it finally worked with notepad++. not really sure why it worked, but it did.
first off, ocnbrze, i want to thank you and everyone else for all the help. I am new to all this but managed to root my phone no problem with the guide...now im trying to learn more and get a better understanding of everything. Im trying to find the leaked version of gingerbread for my rom...ive been looking at mikeg but im not sure if that a good one or not?
edit: also I would like to get rid of the htc skin they put on the phone...does the rom take care of that? or is that just a matter of deleting an htc file?
the new lock screen and the icons on the bottom style is what im looking for...looks like the new ice cream sandwhich pretty much
i merged your to posts together.thanks smitty.
so ive got her rooted and running mikg 2.59...pretty cool stuff so far, really liking it. any other popular mods that alot of people are using?
and is there anything else im missing...i havent partitioned my sd card as of yet...would i do that now or is it even nessessary?
and are kernels worth getting into? i dont know if im at that level yet
EDIT: say i want to change mods...what are the steps to doing that?
EDIT: and when you say keep the backups on my computer...just copy the folder from my sd card on to my desktop? and do i keep the backup still on my sd card?
sorry for all the questionsjust trying to learn
I've done all the steps & I go to the part where I was asked if ClockworkMod is needed , I said Yes. Then the command prompt says "downloading recovery for your phone <supersonic> ...done." the next line reads "Rebooting to fastboot" the last line reads "Flashing recovery over fastboot" it been stuck here for some time.
I have the white screen up on my EVO 4G as well is S-OFF
that is ok. go to the switching recpvery part of the guide and install amon ra 2.3. it is a much better recovery anyways. just download the amon ra file. rename it to PC36IMG, transfer it to the card, reboot into hboot, and select yes to update, flash the su file and you are now fully rooted.
I renamed it , transferred it to the card & do I start the Command Prompt at this point or do the "volume & power button deal"?
