jwhitlock206
so frenchy you saved me thank you
so frenchy you saved me thank you![]()
Now go get your flash on!![]()
i know this isnt related but where do i update my gingerbread rom?
My hboot is 6.16.1002 is that normal after root and if not how do i fix it?
Ive done all steps. I read a post indicating that I did not need to have internt access to dl cwm through revolutionary prompt . Instead I dl cwm from android market But still unable to root. Could this be the problem?
Ok. I was able to resolve my issue. At Hboot screen after updating recovery, I was rebooting device instead of returing back to Hboot and clicking the 'Recovery' option. Which then took me to the ASR screen so that I could run the 'Flash zip from sd card'. Thanks!
Ive already backed up nanroid but didnt choose the 'wimax' option. If I go and back up the nandroid again and include the wimax, will it backup the previous 3 options plus wimax thusly using more space? Or will it just save the wimax with the previous backup (using space adding wimax)?
How do I delete previous nandroid backup? And do I create new nandroid using the same steps as backing up nandroid? (adding the wimax the 2nd time around of course) grattitude in advance guys
what rom is this?i do not recognize it. and the file name has a ruu in the name. are you sure that you are flashing a rom for the evo? do you have a link?After I flashed superwipe I got denied trying to flash the ROM I would like to use. I then restored previous ROM from nandroid restore
Install from sdcard
Finding update package
Opening update package
E:cant open /sdcard/RUU_Runnymede_HTC_Europe_1.05.401.4_R2_Radio_20.5101.30.0822_3822.10.10.12_M_Release_223366_signed.zip
(bad)
Installation aborted
Do I not have the right recovery to flash this ROM?
Using amon ra 2.3
I found it in the link that is provided in the general rom, kernels, themes and more link that is provided in the guide for dummies guide
ok whatever you do do not flash this again. luckily this is a ruu of the stock unrooted rom for the sensation and it is not flashable in recovery. virus linked it because the base for his rom was off of this ruu. he was just giving credit where it is due.
his setup is a little comfusing to get to the rom. but here is his nightly:Directory listing for www.androidfilehost.com/main/EVO_4G_Developers/Virus/Eternity/Buildbox/
you will want to download the 288mb version
When I saw that file I almost crapped my pants! Really lucky it was a ruu and not a flashable!
yep that is a sure way of bricking your phone. so just make sure that you know what you are flashing beforehand. flashing roms meant for other phones will brick it.
