Do you know how I can install Amon Ra besides ROM Manager? It won't let me install it that way. I don't know anything about the APB stuff either.
BTW, I can't even download anything on the XDA site. Any suggestions so I can get the correct version (2.2) of Amon Ra?
you can get amon ra 2.3 from ref#1 in my sig. first you need to rename the file. just erase the amon ra part of the name so that it is named PC36IMG. if you are using windows do not put a ".zip" to the name as windows hides extensions.
transfer the file to the root of your sd card (not in any folder)
power off then press and hold power+vol down
once in hboot (bootlaoder) it will automatically scan for it. just make sure you press vol up for yes when it asks to update.
