on step 9 rebooting from recovery here are the cmds and replys
C:\Users\Mike\Desktop\android>adb push tacoroot.sh /data/local/
adb server is out of date. killing...
* daemon started successfully *
49 KB/s (2129 bytes in 0.042s)
C:\Users\Mike\Desktop\android>adb shell chmod 755 /data/local/tacoroot.sh
C:\Users\Mike\Desktop\android>adb shell /data/local/tacoroot.sh --setup
TacoRoot: HTC Edition v1
By Justin Case (jcase)
Presented by TeamAndIRC, RootzWiki and AndroidPolice
With great assistance from Reid Holland (Erishasnobattery)
TacoRoot: HTC Edition v1 is based on a vulnerability independently discovered by
both Justin Case and Dan Rosenberg (Rosenberg first). I believe unrevoked and
AlpahRev were also aware of it.
Usage:
--recovery : For this exploit to work, you must have booted recovery at least on
ce after your last factory reset.
--setup : Setup the phone for root, must be done before --root.
--root : Root the phone.
--undo : Remove TacoRoot.
Rebooting into recovery, please press Volume+, Volume- and Power at the same tim
e, and reboot the system.
step 10
C:\Users\Mike\Desktop\android>adb shell /data/local/tacoroot.sh --root
Usage:
Rebooting into root.
phone is now in loop after teh 4g animation
loop consit of going form the start up htc evo 4g with white back ground to the 4g animation this gose in a loop over and over
step 11
got the number sign so far so good
step 12
# cat /sdcard/flash_image > /data/flash_image
/sdcard/flash_image: No such file or directory
this is it so far
so you tellme what should i do
