No we didn't give up, the general consensus is you try the HTC dev methodso all you guys are given up i see
I wouldn't put your card in her phone unless you format it, but that will mean erasing it....k guess i well try it again i well changer her card out for mine and try it again to see if it takes tomarrow
well thanks for the confadance
and i have not used my sd card sents i rooted my phone
well that make any diff
k well i am on my laptop so it is freshly downloaded files
the two files you provided in the chat
and i chaged out her sd card with mine so well try it again
yes no maybe
hmmm...just throwing this out there, are you using the same usb cord?so it has to be a issue with phone seeing how i used a diff sd card maybe i dont know
And for the simple fact I am out of ideas, here's my logic....your cord was starting to go bad but you made it thru with doing your phone.yes same cord i used when i did my phone
Yeah, I guess you're right there...I'm really grasping at straws here ya know?if the cord was bad then why is it letting me put the files on there in the first place
why is it letting me inter commands in the cmd promt and the phone up to that point complying with it
