mikemike1234
ocn how do i link this thread to my new one
yes you can stop when done with the HTC dev method, and pick up later at the "get custom recovery" etck mikestony you said you had done this htc dev meth right
do i have ot do the step back to back
i mean would or could there be a stoping poing like if i got all the way threw step 1 and stop for the night and then pick up step 2 tomarroww or do i have to go threw all three steps tonight or at same time
mikestony have a queston again with the taco root.
could the htc sync be a issue with the flash not being instaled or even downloaded properly
or dose it need to be running or any thing like that
Sure, start a new thread if you like.oh other say i should start a new thread cuz it is no root meth and topic
then can you answer my othe rquestions
and i have other sdcards from a prevs phone should i try them
how ever i dont think it would make a diff would you like to know what they are
could it just be the phone itself not allowing the change
think i asked this before. but are there any settings or apps or any thing in the phoen that may make a diff
No.are there any think that i havent tried or doe that you guys can think off
Not sure what you mean.i guess it has been deturmand that the sdcard the file is nto being seen so it has to be the file i keep downloading or the sdcard
cand i check the sdcard like i did with the flash imge can i check it the same way to see if the other file is there would that help deturm what the sissue would be
Do not accept any OTA updates. You can update your prl now or later if you like.k and also a question about my phone that you guys help me root is it safe to do any of the udates like
firmware or the profiel or the prl
dont rember seeing in any guide but i could be wrong
If you are going to do the HTC dev method, nothing gets installed on your sd card.i mean is there a way to check to see if i can see or check to see if the mtd file is on the sd card like i did with the flash img file when i am in the command window
o.k...there a 3 steps to root your phone. (simply put)k can you please read post 539 and 544 and give me your thought or opions to the questions
You mean as far as when you decide to do the Capt method?and on the other suff
