well ki guys i am back at this again the taco root again and i am trying once again .
so thow that rember me here we go
i am using the same exsact files as last time that i used nothing has changed at all in them as from what iam aware of
and i started the root process and i get this far to step
10 when it phoen reboots and i i typ that commaned in i get a dalla sign and nto a nummber sign so here is the commands of what i did
C:\Users\Mike\Desktop\andriod>adb push tacoroot.sh /data/local/
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
86 KB/s (2129 bytes in 0.024s)
C:\Users\Mike\Desktop\andriod>adb shell chmod 755 /data/local/tacoroot.sh
C:\Users\Mike\Desktop\andriod>adb shell /data/local/tacoroot.sh --setup
TacoRoot: HTC Edition v1
By Justin Case (jcase)
Presented by TeamAndIRC, RootzWiki and AndroidPolice
With great assistance from Reid Holland (Erishasnobattery)
TacoRoot: HTC Edition v1 is based on a vulnerability independently discovered by
both Justin Case and Dan Rosenberg (Rosenberg first). I believe unrevoked and
AlpahRev were also aware of it.
Usage:
--recovery : For this exploit to work, you must have booted recovery at least on
ce after your last factory reset.
--setup : Setup the phone for root, must be done before --root.
--root : Root the phone.
--undo : Remove TacoRoot.
Rebooting into recovery, please press Volume+, Volume- and Power at the same tim
e, and reboot the system.
rm failed for /data/data/recovery/log, Permission denied
link failed File exists
C:\Users\Mike\Desktop\andriod>adb shell /data/local/tacoroot.sh --root
Usage:
Rebooting into root.
/data/local/tacoroot.sh: cannot create /data/local.prop: permission denied
so are my images and flash that i put on the root of the sd card are they bad should i redown load them fresh and start over and yes they are there and yes i have verified that they are in the root of the card
the names have not been changed
and as the commandes were put in i copyed them and pasted them so there should not be any errors
