mikemike1234
from what i have been reading on it at least
The dev method is kinda broken down taco yes.yes it is that is why i cant fig out why it is nto working on my wifes
the flasher meth so i should not use it on my phone to change like the splash screen and thing ike that
so let me askik this i dont thing i got a answer to yet
it seems like if i fallow the dev meth it seems like the dev meth is a some what brooken down taco meth
I've gotta log off soon, as I get up early for work..sorryk i well start the dev meth step 1 if you are going ot o say on so i can get threw ti if you can if notthat is cool
but perhaps others will help out.
You use unrevoked at the end of the Capt method which, like I said, can be done later, or not at all if you prefer. After the htcdev method and flashing custom recovery and su zip, you can flash roms/kernels etc.i guess once i use the dev meth and unlock it i cant use the unrevoked is that right
The only files you need are the ones ocn gives you in the thread. The only files you use from the "Google Android SDK" are the ones he provides. He just made it easy for you, so you don't have to download the whole SDK.here is a quesion there somthing miss leadin here is say on your form that you need these files
the setup
you will need to download these files:
make
- <LI sizset="247" sizcache041435762197454306="1">adb.exe <LI sizset="248" sizcache041435762197454306="1">fastboot.exe <LI sizset="249" sizcache041435762197454306="1">AdbWinApi.dll <LI sizset="250" sizcache041435762197454306="1">HTC Sync 3.0.5551
- Java Runtime Environment (JRE)
the dev website says you also need thsi file
Google Android SDK zip
so do i need it or not
