Root [Theme] NexTheme for Droid X Froyo 2.2 (8/26/2010)
Is that custom Launcher shown in the original screenshots part of the theme itself, or are you running a custom Launcher app?
That launcher is LauncherPro. It's not part of the theme. You can get it from the market for free though, and it's much better than the default launcher, IMO.
Nothing wrong with alittle ADW either... Black Gloss theme goes well with NexTheme...
I originally had Launcher Pro, but I found that it had a fatal flaw: the dock downsizes icons to (what appears to be) the same size as those found on the regular Droid. Unfortunately, since the X's screen is so much larger, this leads to icons that seem ridiculously small by context.
I wish there was a way to make the icons the same size as the stock X icons. I also wish that there was a way to alter the dock/dock icons by using themes like NexTheme (not sure if that last one is already possible or not).
I'm about to install this deodexed nandroid image. It better work! I need my phone to make the 5 hour drive back to Illinois, haha.
Then, it's just a matter of redoing the framework and services.jar for 2.2 before this is running :)
Awesome, looking forward to theming my Froyo X
Do you guys want the battery percentage in the bar?
Would love without (since I now have that awesome battery widget from your earlier post in this 2.1 thread theme), but I would also love for you to do whatever you want to do.
Also, I hope you took that beer break.
Thanks much for your efforts!
