Root [Theme] NexTheme for Droid X Froyo 2.2 (8/26/2010)
I installed the theme and everything seems to be working fine. My question is regarding the font. Did it change from V2? I don't remember the font being so "script" like. Any chance of going back to the stock font?
Thanks - I love everything else.
yeah its in the OP
FAB - Thank you Man! It really is awesome and IMHO looks so much "cleaner" with the straight battery. Appreciate you being willing to "cater" and throw a couple options out there. Also appreciate you putting it out so quickly!
Again, thanks!
Hey. I'm trying to install this and for some reason my phone no longer let me mount my sd card in recovery mode. Does anyone know why this could be? I'm rooted with Froyo installed it mounted fine before Froyo.
EDIT:Nevermind. Uninstalled then reinstalled Bootstrap and now it works. :-)
Had no problem applying this theme to my deodexed DX 2,2. Thanks Fabolous. Looking forward to more themes.
Much easier time deodexing and applying themes than I had updating to Froyo.
OP updated w/ new files and instructions.
The battery percentages are now optional, and by default, NOT included.
Thanks for the awesome theme, I haven't decided if I'm going to go without the battery percent since I applied your theme last night, I definitely like the font though, I'm not goin back to default, thank you for the options though, keep up the great work!
Fab I cannot seem to get the Battery percentages to install. keeps saying E:can't open /sdcard/Battery_Percentage_Froyo_DX.zip (bad) installation aborted. Any ideas? Other than this I installed the theme that I know and love without any problems.
If I like the status bar that I have now, is there a way to apply the remainder of the theme without changing it ?
TYIA
Poop....
Figured as much.
Thank you sir
Actually I just made it for you, I tested it for about 5 min, and I applied it through clockwork, I was already running nextheme also. I am uploading it now and I will give you some instructions:D
Here ya go it not perfect but its close. I am going to see if I can improve on it but for now you can see what it looks like. All the themed apps are there, I tried to put some on one page(pic 3). And the settings are themed but the menu is not. Check out the links in the OP on how to deodex first, because you have to be deodexed. I would do the nandroid.
Edit: V2 released, I changed some of the menu icons but its still not perfect
Here is the link
teenfaces_nextheme_v2
Wow...
I really appreciate this !
Thank you :D
Ok, so on 2.1 I only installed the framework and services part to get me the black notification bar. I'm not seeing that option here it looks like. So I'm thinking of installing the whole theme. Now, I've already got LP+ installed and some custom icons on my dock, is this going to change all them as well?
it will only change the ones that are themed
oh you are using LP icons, yeah you can easily change them back
ok thank you sir. Now off to the deodexing thread to see if I can manage to figure that out... that should be interesting... once I get it deodexed i'll be doing this. gives me something to do while at work today lol.
