monticello
Thanks, I'll try again and post backYou don't have to pay us for help.. This phone doesn't use Odin nor .tar files, only the LG Flash Tool, .dll & .tot files. What step are you stuck at? Screenshots to show us??
It disconnects/reconnects after about 30 seconds in download mode. Also I cant see me phone in device manager.
OK that's good, that's suppose to happen. Did you ever configure your ports yet?
Addendum:
Although recovery still works, this is the error I get when trying to flash the simplicity zip file:
file_getprop: failed to stat "/system/build.prop": No such file or directory
I feel sick.
That's because the rom dev has the installer check the build.prop to make sure your flashing the rom on the correct device. If you're bricked or wiped pryor to flashing then your build.prop is likely missing, hence the rom not installing and giving that error.
So does that mean I am S.O.L.? or is there a way to undo this damage? I have Philz recovery working...
1. you can unzip the rom and make the adjustment to the updater script
2. or ask the developer if he can help
3. or ask someone to post a backup that you can restore in recovery
I'm sure there's more options I'm not thinking of right now. Point is your phone is recoverable. Unbricking with the kdz has never failed me.
Can you got into downloaded mode?Sorry for the noob questions here, I am still struggling with this F7 that won't boot, stuck in a recovery bootloop.
Who (or where should I post) to ask for a backup to restore in recovery? I need some way to get recovery to recognize the /data so I can try to unbrick this thing... or other solutions. I can't believe I did this.
TIA
Yes I can get into download mode, have tried this 15 or 20 times. Started another thread on the main page, but so far I can't find a solution. Game Theory developer said the build.prop is missing, that I need to change the script, but I don't know what to change. Can anyone help? Seems like this shouldn't be that hard to fix...Can you got into downloaded mode?
Is LG870ZV4_06 still the recent most firmware build? I've been routed for quite some time now..
This is actually quite surprising. I last updated this phone over a year ago. I use to flash to stock just see if there were any updates. There were never any. I thought they weren't gonna update this phone any longer. I don't expect much of a change of course but, it'll be nice to at least have some kind of update..How long does it to take after you hit the arrow? Mine says ready but nothing ever starts? It just says ready and thats it. I just got this phone and cannot afford another right now. Help is appreciated. Thanks in advance.
