DannyJSlone
I might have a problem. My messenger app keeps crashing every time I try to send or receive a photo.
I did another clean install and all is good. I had a mod on my phone screwing it up. Man i love this ROM.
Sounds like you also formatted data in twrp. That option wipes everything from the phone.... Your only recourse is to use adb to push a rom/gapps to your phone
Well, crap
I thought to erase the sdcard you had to manually select it. I understand how that happened.
I will dig around and see if I can find Scary Aliens instructions on how to push those to my phone...unless someone has the links handy.
Sorry man...not what I meant by wiping data (wipe data and factory reset are the same things and I listed both...my apologies for not being clear enough!). I do not like how TWRP has them listed in the same "wipe" directory.
Put the ROM files in your sdk tools folder.
From your default directory (should be something like C:/android-sdk/tools):
adb push <path to file on phone> <path to location on device>
For example: adb push file.zip /sdcard/file.zip
I believe you have to be in recovery in order to use adb.
Just cough when you do it lolIs there a way to bring back the option to mute camera under volume settings?
When you say I have to be in recovery, do you mean boot up the phone by holding down both volume keys and then the power button and then once it comes up just select "recovery mode"? If not, then do explain please. Been dealing with this off and on all day and the wife is going to kill me if I spend any more time on it![]()
may add kicked in... stopped reading after under the topic
the release has a feature where you can add shortcuts to the lockscreen....more tweaks and speed![]()
You're using TWRP right? Just boot into that and then connect your phone to the computer via the USB cable. If you want to test if your ADB connection is working, just type:
adb reboot
That should reboot your phone. If it doesn't, you need to reconfigure ADB.
How do i make the keyboard make sound when i touch it
Yep there it was and if i wasnt for you i woulda never unchecked the block offensive words box lol
Please add the camera sound option back in. Those in states that outlaw it can just leave it checked
I'll flash this when I get a moment later. Maybe it's time for a full wipe.
OK, guys and gals! Just installed 4.4 last night (good job BTW JBS crew!) and decided to try the old photo transfer thing with the wife's Galaxy S3. I have both phones NFC turned on, her phone has S-Beam turned on (it's upgraded to latest Verizon OTA Jelly Bean), and my phone has Android Beam turned on. I was able to beam a photo through Gallery to her S3 with no problems. Hooray, I thought! I can finally impress her with this. Tried beaming a pic from her phone to mine and - what the $%#@! - Google Play Store opens up and tries to receive it with no success!
The faint ripping sound you may have just heard was the last of my hair being torn out! Like many have said, "They make this look so easy on TV".
Any thoughts on why this is happening (the Play Store thing - I know about Samsung's effort to steal Android Beam for themselves)? Is there another app I can use instead of Gallery that may make this work? Am I beating this to death? HELP!
(serenety now, serenety now, serenety now...)
