How come there are no boot animations with sound?
i know this isnt a kernel thread but i like/trust here...
question for the knowledgeable, will increases cpu from say 1.0 ghz to 1.2 have a theoretical gain or decrease in battery/temps/etc?
i know the higher speed will kill the battery faster but on the flipside having the extra kick will get process(s) done faster so it can scale back faster so i can see the argument for better/worse battery and hotter/cooler temps... any thoughts?
One man......Alone.........betrayed by the phone he lovesjelly bean broke it.....
figure it out and you will be a hero!!!!
Is it because the startup scan for multi userPlease tell me the rom with jb 4.2.1 that has boot audio and ill get it in.
Since i haven't seen anyone getting it to work since JB along with myself we dont currently offer boot ani's with sound because there is no sound.
Truly enjoying this ROM. I've given up trying to try every option. It's just too much. Anyone try that LMT or button savior extra apps? I d/l'd lmt but was too busy to figure it out.
I have never had a problem with Apex Pro or these ROMs EXCEPT this annoying BT issue. I bet my BT headset drops connection 10x a day on 4.4. This is with a CLEAN FLASH. I think I'll try my old BT headset to isolate the issue to the headset or the ROM...
Good idea....
Another is to stop buying the headsets at "discountheadsets.com"
Hey, my $20 BT headset sounds phenomenal!
WHEN it connects
Sorry man...not what I meant by wiping data (wipe data and factory reset are the same things and I listed both...my apologies for not being clear enough!) . I do not like how TWRP has them listed in the same "wipe" directory.
Put the ROM files in your sdk tools folder.
From your default directory (should be something like C:/android-sdk/tools):
adb push <path to file on phone> <path to location on device>
For example: adb push file.zip /sdcard/file.zip
The problem isnt that your recovery cant ready sdcard/0.
The problem is that your data is in sdcard/0...it should be in sdcard........
Data/media/0 is where your info is actually stored, sdcard is a symlink to that location. Move all of your data to the sdcard root and you should be fine moving forward
because at some point you installed a 4.2 rom while using a recovery that was not ready for the new multi-user
goto Data/Media/0
inside that folder do you have another /0 folder?
If you do, you need to move those files back to the data/media/0 folder. your SDcard folder will follow suit
