bigbear6708
I'm having a little issue trying to set a family pic as my lock screen wall paper..i keep getting jbsettings is not responding...this is my first attempt at lockscreen wall paper, did i miss something
Did you un-install updates to gmail before you started?
inverted gapps dont always play nice. probably lose your dialer without manual intervention
Hey, guys. Just tried the inverted theme but my gmail is still the boring white. Any suggestions? Also, should I just do the inverted Gapps route instead? What are the pros, cons and so on? Thanks a lot.
Yikes, don't want to mess with Gapps then. No, and I apologize, I didn't know I had to do the uninstall updates thing and unsure where I'd do that... In Google Play store?
OK, this is hands down the most customizable JB ROM out there.
However, I am getting frustrated with my ignored requests.
FACEBOOK CONTACT INTEGRATION!
This rom is touted as the one with the most Dev support and responses, yet my request for this feature continues to be ignored. Why?
Eagle said that there was a security issue, and that it is easy to add back; I have yet to find the security issue (as I have posted), the only one I find is that it is an internal competition issue between Facebook and Google+. And eagle has not responded since I asked him up front to answer.
So I guess I will be a squeaky wheel in this thread until I get a clear answer.
Please, please, please; either give me a firm link about the security issue/broke stuff or I will have no choice but to continue squeaking here and elsewhere until my axle gets greased.
Thank you.
p.s. I want to stress that I truly like this rom, but truly wish that the feature for which I ask could either be addressed and/or added back in.
You do that in Settings and Apps... scroll over to "All" scroll down to the app and click on "uninstall updates"
then install the theme again..should be good to go
I apologize, but when I go into Settings, apps, all, gmail, I don't see an option for uninstall updates. I see force stop and so on, but not that one.
Thank you.
Then for gmail you are fine.. If there ws an update you would have the option to un-install updates
The reason your question has not been addressed is eagle is busy rebuilding his computer after a fried motherboard. Hopefully that is enough grease on that squeaky wheel, as we will decide what and when to include items into the rom..
For me, the email list is inverted, the actual email is white
Nope, list is white and emails are white.
you did load both the inverted 2.3 and the extras 2.3 right?
Mine must have been inverted due to running beanpicker... Tried a new install and no changesLooking at other options, but for now gmail isnt inverted...
