bigbear6708
It may depend what gapps you are using, and or if Johnny b every got around to theming the new Gmail. I know his bean picker extras were themed from an older version of Gmail, hence why it may not work for you.
OK, this is hands down the most customizable JB ROM out there.
However, I am getting frustrated with my ignored requests.
FACEBOOK CONTACT INTEGRATION!
This rom is touted as the one with the most Dev support and responses, yet my request for this feature continues to be ignored. Why?
Eagle said that there was a security issue, and that it is easy to add back; I have yet to find the security issue (as I have posted), the only one I find is that it is an internal competition issue between Facebook and Google+. And eagle has not responded since I asked him up front to answer.
So I guess I will be a squeaky wheel in this thread until I get a clear answer.
Please, please, please; either give me a firm link about the security issue/broke stuff or I will have no choice but to continue squeaking here and elsewhere until my axle gets greased.
Thank you.
p.s. I want to stress that I truly like this rom, but truly wish that the feature for which I ask could either be addressed and/or added back in.
*228 does NOT have a dialpad on mine either. I had to use *22899 to update PRL.
This is a facebook issue not our issue.
as stated in this link
Galaxy Nexus ICS ROM restores Facebook contacts sync - SlashGear
It is our decision that until facebook follows the google standard its not something we Plan on including at this time.
Thats whats great about custom roms many options out there.
I Believe BlackDroid has this in CNA.
Dont know what others. Just not something we are interested in doing at this time
I may have confused security with the issue stated above, alot of things come my way.
But Security still comes to mind just not sure where i got that.
Just wanted to make sure that i answered your question!
Worked great.Go into Control center > Navigation bar > Menu and click on reset nav Bar
This will reset your nav bar settings.. go into toolbox and download the blossom keys again.. and you are good to go
Try a reboot....Try changing settings back to how they were before...
Don't know what you changed so hard to say how to fix![]()
Yeah I had the same problem with Apex update breaking things. Unfortunately I couldn't access Titanium but I had a nandroid from several days ago so that'll get me close enough.
Love this ROM...cant get LMT to work though...don't use full screen as much as with ICS, so not deal breaker. Just thought I would throw it out there. Gets FCs often. Thoughts?
