Factory data reset (wipe data/cache)
go Advanced, wipe Dalvik cache
go back and then to mounts, format /system
go back and then to install .zip from SDCARD
flash rom, then gapps, *then FB sync file* (don't do this, see below)
reboot into system
profit, except for the *
All
Talking with Eagle and we are aware of the bluetooth issue and are able to reproduce it.
Restarting phone and not turning on Bluetooth seems to be temp fix but we will get a fix out asap.
I love the new 2.4
Just need to verify, since trinity is built in is it ok to flash in lean kernel?
Lean is still on 4.3.0
Posted this on sorcery forum. But did clean flash of 2.4 and new gapps. My gmail (app) acted funny. If I read an email, it would still show it as u read. Also any email with an attach was stuck on sending. Tried everything to correct. Finally reflashed 2.4 with gapps from 2.3. And success ! Not sure if this is I'll advised
1st 2 is probably the same issue.. didnt make a good connection to the server.
Nothing different in the tools from 2.3 to 2.4
Can install the non inverted gapps.. should work perfectly for you
oh i'm up on the new version so far so good
One question though, where the heck is the place to change the color of the power widgets on the pull down? I can't find it :/
Hey there Eagle & other developers:
That weird Bluetooth issue I've been having just resolved! What was the issue? Apparently the kernel!
On your recommendation, I flashed off the stock and/or Trinity kernel and onto Lean 4.3.0. Rebooted the phone and the headset. On bootup, they paired up and I hit the Play button. Instant music!![]()
Not sure how to attribute this, except to the ages-old Navy term PFM*.
*- PFM: a term used by Navy Electronics Technicians to explain how equipment and systems seemingly fix themselves, with proven symptoms disappearing without any external influence. Stands for "Pure (Freaking) Magic".
EDIT: So you want us to flash two kernels, right? Franco and then our kernel of choice? Same recovery session or two different sessions?
roflmao
one of my favorite movies of all time....
