13 plus hours on stock 2.4, this rom rocks
are you referring to battery time? if so, details and/or setup ...
Question. If I prefer to use the 1.0.2 radios (as no BT issues) ...any adverse effects?
Sourcery is only for the Galaxy Nexus. Loading roms for a completely different phone will always cause a bootloop. may have a negative consequence on your phone in the long run, but that is mere speculation on my part.It's a captivate. The first time I tried I wasn't familiar w/ the Dalvic cache location so zI didn't remove that. With that exception, everything else was per the tutorial. Would like to try it out - the rom I am using now had aroma installer but I still had to run it 2-3 times before it finally booted into something besides recovery - but it finally worked. Anotherwords, I got into a custom rom but it was a back door fluke for lack of a better description. The difference it seems is that a compatible kernel was loaded with the rom. Is this kernel (devil) now on my os (and it will work w/ JB Sourcery) regardless or do I need to load another kernel for Sourcery to work?
Is there any way to do this? I LOVE this ROM, but hate having to redo all my customizations again. There's so many of them I have a hard time remembering which ones I changed, let alone what type of change I selected to make the change.....AAGH! Error! Error! Faul...ty! Must ster...i...lize...Is there any plan - or even ability - to backup JBSourcery system settings? It'd be great to have ringtones, notification sounds, soft key and battery mod options, etc. saved to we can automatically resotre them.
No doubt it has been suggested and I missed it, but is it even possible without messing up a whole lot of other stuff?
are you doing anything when it happens?
Try a dirty install, rom and gapps... maybe something didnt fully load the 1st time...
Ive not had that one before, so at a loss as to what would cause it.
OK I flashed the Franco kernel and then back to an earlier Trinity and now my battery stats are blank. All that shows is what's left and how long on battery.
they go away, or start over..right?
No. They just go away. I ran all day today like that with no battery stats. Tonite I restored to my last backup of 2.4 so I could have my stats back. At this point I am seeing brcm_patchram_plus in battery and my kernel version (via settings -> about phone) is 3.0.31-04229-glb829f6-dirty.
TIA
Actually the perm fix aka JBSourcery 2.5 is about to roll down the pipeline...
ha, dont start a eta rumor now...and besides i just got 2.4 right on my phone lol
