[Verizon] [rom]jbsourcery v5.4-lte[06/07/13] jb4.2.2 The Final Call
I am currently running JBSourcery 2.3, and haven't tried any 4.2 ROMs yet. If I get the newest version of TWRP, will I still end up having to mess around with my directories, or should it all be taken care of automatically?
With the newest version it takes care of it. (at least it did for me) I JUST upgraded to sourcery 4.2.1 yesterday (Running TWRP 2.3.1 I think) and everything just "worked"
the statusbar mods, dont need a reboot. the systemui will reset itself automatically. The cobalt in particular I know works as Ive modified it in the last few days. Check your toggles, should look much different. For boot animations, you get a small note at the bottom of the screen that it has finished.. next reboot you should see the new animation. I just installed 1 as I typed this and it is working.
Well they did apply this time but the results are not good. My whole theme seems messed up in various places. Buttons aren't looking normal, can't read many things because of it. That's both cobalts, system ui and status bar mod. Tried reverting to stock and no dice. I'm going to have to reflash I'm afraid.
So this was happening to me on Xenon RC3 and thought it was a rom issue, but it's happening on Sourcery as well so I'm guessing it's a 4.2 issue. For whatever reason, if I haven't used my phone for 5 mins or so, my Wifi turns itself off and then turns back on when I turn my screen on.
It's killing my battery because it's connecting and reconnecting. Anyone else have this issue? Keep Wifi On While Asleep is set to Always so it's not that
All I can say is what Comic Book Guy would say: BEST......ROM.......EVER!! I'm STILL finding stuff! Christmas came early this year!
Is Google now not working fit anyone else? When I swipe up from the home button it just brings up a search bar. No cards or the cool little picture at the top. Any ideas?
means you didnt opt in the 1st time you went into google now... Clear defaults to it and go into it again.. should allow you to opt in
Spent all afternoon flashing Sourcery 4.0 Twice... Using the latest TWRP, downloaded last night. I wiped Dalvik, cache, system and Data (Factory Reset) All goes well except Google search FC each and every time I open Google Now, or speak to text on the messenger. What did I do wrong?
Downloads MD5 checked out ok both on Gapps and rom...am on the standard Gapps.
Restored back to 3.2 for now and that was a pain, restoring from the /0 folder thing sucks.
Yeah that's what I thought too and I did that before I even posted here lol. It still just brings up the search bar and nothing else.
which version # twrp?
When you get the search screen, click on the settings button.. then click settings and turn on google now
So I finally got it to work right for me, I think it was just the file downloads I had to do. OH, and a big thumbs up to Chief's page walkthrough. Only issue I had, was that I created a backup (and titanium update.zip) and then couldn't find them after flashing, because of the directory change. Ended up finally going into File Manager in recovery and moving them manually. It's definitely the one thing that makes it a pain; the folders aren't visable without going into Recovery. It'd be so much easier to merge folders and whatnot, if I could just see them all while hooked to the PC. Thankfully, the main things were just photos, so that wasn't too bad to move over.
Now it's time to play again!
OH! quick question: Whenever I wake the phone, there's a half second where I can see the white screen outlines of the neighboring screens. It won't let me get a screen with it that way, but it's almost like seeing ] [ on the outside edges. I thought I heard someone else mention it, but it's the only thing I wish I could change off-hand. Well that, I kinda do miss my old toggles, but there is so much to play with!
Data/media/0/sourcerytools/kernels and is named sourcery_stock_Kernel.zip. just downloaded fine for me
hmmm thanks for trying it. i'll try again and follow that exact folder path to find it. i thought i checked everywhere though...
edit: wait a second, i do have one called "sourcerizer 12-12-2012" under kernels, is that it?
That is the new lockscreen for 4.2. Grab the white bar on the left side and scroll to the left and you can add a single widget on multiple lockscreen pages.. Scroll to the right and it will bring up the camera.
Edit: that's the one refered to as "jbousroucery 4.0 sourcerizer kernel", right? thanks
The 4.0 kernel is called Sourcerizer-12_12_2012.zip and is in the same folder.
eureka! i've got it, had it all along. thought that was the new gapps that just came out. i'm stupid lol
that's the one that comes with this new release, right? i noticed the other stock kernel too that you mentioned. thanks again!
