For those suffering from BT range you could try this.
Please post back if it helped and I'll add to the OP
Id like to flash jelly belly 1.8. Is GPS fixed though? If not, I am going to pass. What is the recommended way to flash successfully coming from AOKP b40?
Thanks.
If I want to flash add ons, like the circlemod battery.... can I just flash that in cwm at anytime after installing the rom?
What a bummer. Well, nothin' wrong with stock at all on this phone
Ok, about to do my first dirty flash ever. No need to wipe anything, not even Cache?
Going from Jelly Belly 1.7 to 1.8
Hey Jbdan:
I am not a coder, so I can't vouch for whether or not that BT fix has anything in it other than a BT fix, but I took that bait and I can say this:
THAT BT FIX WORKS!
Yesterday I couldn't use my BT headset outside. It would break up and hardly connect if I turned my head wrong. Now, no problems!
Thanks for posting it... feel free to include it in the OP.
Just did my first ever dirty flash
I feel so dirty
Initial notes on 1.8:
- Boots up a helluva lot faster than 1.7
- Just as snappy as before
- Apex Launcher is working again thanks to a developer update
- Still having volume issue (no sounds for any notifications like texts)
Any way I can tell if GPS is locking on? I don't think it is, Maps is showing me in the middle of the freeway.
For anyone having volume issues, for some reason the default ringtone and text tone is set to silent. Fix that, voila sound.
That really is a ridiculous option, why is there an option for a silent ringtone... that's about as useful as a screen door on a submarine.
I'm still trying to find out what the "fixed volume issue" change is in the changelog. I had previously thought it was going to boost the volume some like present AOKP and CM9, but it didn't on my end. Anyone else seeing any difference in the volume?
Check in the OP and use the third option (Deep Sleep Issue Fixes) for a gps/location fix. It also is a deep sleep fix so you kill 2 birds with one stone....hopefully![]()
