andoird213
Android Expert
Liquid smooth Jellybean incoming...
I've run into a major issue with 3.4. My phone random rebooted, and now is bootlooping. I tried clean flashing the build again, but it keeps failing. Restoring a nandroid keeps failing during restoring data. Looks like I have to flash back to stock.
What other settings/mods have you tweaked/added?
Nav worked great 100% perfect says all road names etc... Re-installing CWM touch though have had some random issues and it all started with twrp. Re-installing 3.4 with cwm this time @ the pet store grabbing some shampoo for my girlSpit.
Everyone on Rootz is recommending a full wipe and a re-install. I don't wanna!
I'll wait for your input and see if you have the same issue. If not, then wipe I shall
Ah, the price we pay for being on the bleeding edge of technology here...
^ this, let us knowWhat other settings/mods have you tweaked/added?
^ this, let us know
That's just it through, I hadn't gotten to flashing mods yet, i really only froze a couple of the google apps that I don't need. It's totally bizarre that this happened
Has it always done this? Even before you were on JB? Have you flashed different radios?Well I went out again and I noticed that I can't seem to stay locked in on the data signal at times. Maybe it's an actual weakness in the signal it's pulling in, but when it shows me having 2 bars of 3g data, the 3g will keep turning off and on, off and on. Doesn't change from being blue or anything, just shows a drop of it. Usually in this same area I can keep a strong 3g connection though, so that's what has me wondering...
Sounds good that is a good troubleshoot ideaNever done it before with the previous JB roms or ICS. As far as radios go, I'm still using the FC04/FC05 radios. I'm just going to try and go back to an earlier version of JB to see if I still have the same fluctuation with the signal.
Nav worked great 100% perfect says all road names etc... Re-installing CWM touch though have had some random issues and it all started with twrp. Re-installing 3.4 with cwm this time @ the pet store grabbing some shampoo for my girl![]()
Your making me second guess my recent upgrade to twrp. I may have to go back to cwm if that seems to be the more stable. Anyone else have an opinion?
Go ahead, the Nav Lady issue is FIXED!
Just took a 2 mile test drive. I cleared Maps data in Settings, re-booted the phone for good luck and she got me all the way home.
Flash away, Bud!
I think we need a name for the Nav Lady. On ICS, I think her name was Maude. She sounded really old.
