DannyJSlone
Up and running. Dirty flashed from 3.5 with full screen mod and circle battery. All seems to be running well.
:thumbup: :rock:Bleeding Edge!!!
I heard 3.7 has stock kernel NOT the linaro compiled stock kernel. Confirm me ryan?![]()
That would be correct...not Linaro.
The past builds of jelly belly have included by default the stock Google CWL (compiled with linaro) kernel. WHat does this mean? I'm not sure exactlyNo linaro....is this good or bad? Excuse my noobness. I have yet yo flash JB. I've been running AOKP M6 and have been suspect on the idea of flashing a shaky from with a lot of reported issues( not directing it at this from)
other than it being compiled with a toolchain that optimizes software. The stock Google kernel in my experience has actually been even more smooth to me than the linaro compiled stock kernel. I use franco's JB kernels though so I haven't thoroughly tested the differences between the stock vs stock cwl (compiled with linaro).
The past builds of jelly belly have included by default the stock Google CWL (compiled with linaro) kernel. WHat does this mean? I'm not sure exactlyother than it being compiled with a toolchain that optimizes software. The stock Google kernel in my experience has actually been even more smooth to me than the linaro compiled stock kernel. I use franco's JB kernels though so I haven't thoroughly tested the differences between the stock vs stock cwl (compiled with linaro).
Jb is very stable imo. For me to have flashed 4 different JB roms and flash 10+ versions of those roms and to only have had very minor issues is good stuff.
Whatever you do, before you take the plunge, research all you can on it so you understand what you're doing and make a backup of your /sdcard to your PC.
Didn't mean to answer for ryan just giving my input![]()
That's fine I meant to quote both of y'all anyways. Lol. But I guess I'll create a nandroid then copy that to my CPU via USB.
But hey..I don't see any 7-14 gapps package...where is it?
But hey...I know i
But hey...I know i
In the 1st post in this thread are all the links you need. When you click on the link to take you to the 3.6 Jelly Belly version scroll down jakedays post and you'll see all the links.
And I forgot to mention....wait!!! 3.7 and 7/18 gapps are about to drop so you might as well wait for it![]()
Don't do that...you need 7/18 gapps with 3.7UUGGHH... I was getting ready to flash 3.7 and use 7-14 GAPPS.. how long do u think until the 7-18 releases? Today? B-)
It'll be official tonight sometime. Or you can beg and plead with fellow countryman and AF user "ryanmatchett" for his "secret early release links"
In the OP is a **early release link![]()
Downloaded 3.7 and 7/18 GApps on my phone at work, md5 checked out. Moved them from sdcard/Downloads to sdcard when I got home, checked md5's one more time (because I'm OCD) and they didn't match. Checked the file size and it was 0 kB. Somehow the file got messed up moving from folder to folder in Root Explorer. Re-downloading now, and thank goodness for md5's!
