Where's that history details screen?
Oh crap..I have been clicking "Run - Restore missing apps + all system data" in Titanium. Is this wrong.What should I be clicking to backup and what should I clicking to restore?
If I'm that far off, maybe I should delete all backups and start over?
Ok, now I'm more confused than ever. I selected the first option "Restore missing apps + data" and my apps are in the drawer, but nothing is on my home screen. Is this what you guys do? Wow I thought I knew what i was doing.
Anyone else running into network connectivity issues? Searched and haven't noticed any.
Mine is refusing to connect to wi-fi or 3g at all (no 4g in my area). Worked for the first hour though.
Flashed 3.6 earlier today, came from 2.6. I wiped dalvik cache, cache, factory wipe, etc. Loaded apps and data from titanium backup.
In titanium, you should always backup by clicking:
Backup all user apps + system data
And for me, I make sure to uncheck to restore from Google at the initial install, and then install TIBU from the play store manually (plus I have the pro version), and then in TIBU, restore by clicking:
At that point it should give you a list of all your apps, either select all you want or just verify what is checked. HOWEVER make sure to NOT restore anything that says Google on it or what may be system apps. If you want any of those, download them from the play store.
then you can manually select things on the list that are green, like launcher, alarms, accounts,etc..
That is exactly how I do it other than I use the autoscheduler and also redo backups for modified data midway through a 1 week cycle.
And that is why it's a good idea to backup all apps + system data. You don't necessarily have to restore system data, but there are certain conditions (roms of same framework) where it can come in handy so it's insurance to back it up just in case.
Just randomly happened why did you do those reboots? What recovery are you using to restore your 3.5? Just curiousOK after some weird reboots 3.6 finally Gave out and just kept boot looping. It was a clean install as well. Luckily I had a back up of 3.5 which seems to be running well. Guess I will stay here until 3.7 comes out.
+1 (at least)
I also use auto scheduler as well, and update to drop box for modified 2X per week and Gdrive for 2X per week full backups...just me tho. Oh and I copy my phone contents to my PC about 2-3 times a week. So I will never be without a backup.
Wow I guess I have a few backups!!
Have a good night all..and here is hoping for a new build tomorrow!! Or at least something to flash!
OK so earlier I was talking about Google now not working for the weather. It seems to be a Google now problem and not a ROM problem. The ROM runs great so far. Version 3.6 here. The weather works sometimes and sometimes it doesn't so I am pretty sure it is a Google problem.
Is anyone using swype? If so, is it working ok? Mine will not auto space or auto capitalize in the stock browser.
Edit:...This should say swype instead of skype.
yeah, it's been like that since the switch to JB for me
