Although I rooted an LG Optimus V last year (so that I could use Link2SD), I'm still a newbie because I don't really understand how any of this works. But I just bought a Victory and would like to root it before... well, before I do pretty much anything with it.
First question: should I activate the phone before or after rooting? Does it matter?
Second question: what's all this about a "custom recovery"? Is that different from installing a custom ROM? I don't want the phone to function any differently; I want to use the normal Android 4.1.2 operating system that it came with, but I want to have root access for certain things.
So the custom recovery is a startup program that you only have to run ONCE, in order to do whatever needs to be done to give yourself root privileges, and after that it's not used again?A custom recovery is the utility you boot into in order to "flash" zips such as custom roms to your device as well as other functions. It will not change the performance of the phone. Recovery is booted into by holding the volume up button while powering up the phone. Your stock device has a stock recovery on it right now.
so, I am working on rooting this bad boy and for some reason I am unable to copy the files from my PC to the SD card. I have it connected as as Media Device... The PC recognizes the phones SDcard but won't let me drag and drop.
What am I missing?? I have never had this issue with any other Android phone.
Thanks in advance for the help!
LC
Success!! Thanks for the tip on using the web browser on the phone to download. Worked like a charm!
LC
ok got that but for some reason i cant get to the bottom of odin where the start button is. I have a small computer but i dont know if thats why. I cant move it up and the start button is on the bottom. I know its a silly problem but its stopping me.
