I downloaded this ROM and decided NOT to install it, as I would like to be able to UNDERCLOCK the kernel to save power.
I got this fully working in the on the Sprint. Can't connect to lte but I got 3G. Weak 3g
Would someone mind posting the deodexed s-voice apk. I'm having a bit of pc issues so I'm unable to get it at moment. Thanks in advance
While the RedSpot Uncapped kernel does not specifically underclock, it also does not spcecifically overclock, it only uncapps the clock speed limits. As you can see from CPU-Z, the range of the clock speed at the time I took this was as low as 384Mz and as high as 1.51GHz. While just sitting on the charger with the screen on and a few widgets running, it stays between 384-918MHz most of the time:
You may chose NOT to install it, that's NOT going to hurt my feelings!![]()
Thanks for clearing that up Jerry! A quick question for you. Does this ROM still have the "Power Save" button? I just found it yesterday and it appears to have solved my battery problems... Woke up this morning with it at 86% without having to leave it on the umbilical cord!
After installing the rom the wifi tether treve mod crashes when starting tethering. Is anyone else having this issue?
Try copying your lib folder from the stock Sprint 4.1.2 to your phone's lib folder, overwriting everything. Be sure to have a backup first! Reboot and see if that helps. You will probably need a few of the Sprint apps as well, but I do not touch the modem, so that should not be affected by an install of Victorious, you just need the apps and libs to properly access it.
Of course, when trying to port a ROM from one phone to another, logcat is your friend!![]()
Could you explain or less me to a thread that explains low-fa logcat? I copied and overwrote the lib with no success. And which Sprint apps do you think I'll need?
First of all, great job with the release! I've been enjoying it so far! The only negative is that for whatever reason, my battery seems to die 3x as fast now. With me thinking like I still have my Evo 3D, I went and wiped the phone, and then installed this. So... yeah, now I'm in a world of hurt (didn't check the forums before doing it). I had two backups but they don't seem to be working at all which kind of sucks. hard.
Currently I'm downloading the stock rom. Hoping to reinstall your rom asap and in turn am hoping that it won't drain my battery again. I'll let you know how it goes.
EDIT: So I hit a brick wall, guys. I need some help because I really don't want to lose my phone (its not "bricked"). I download VMOBI's stock ROM but I installed clockworkmod (no idea when) and keeps saying MD5 mismatch when I try to restore the stock ROM. I can't access my backup that I found which is when I backed up my original ROM (virgin mobile -- untouched). Would rather have the other recovery program, but I have no idea where to find it.
3 AM crazyness is going into full swing so yeah. I need sleep. =S
EDIT 2: Lastly, Jerry. I hope you release a full version of this. I would solve another guy like myself to get out of this sort of situation easier. I know another guy whose ROM I used on my Evo 3D used the site: Goo.im free android file hosting.
EDIT 3: Made a thread for helping me with my issue, check it out if you want to help out! Thanks - http://androidforums.com/virgin-mob...lp-reinstalling-stock-vm-rom.html#post5958039
Hey guys, I have been reading and rereading this forum now for a couple of hours... and i just have a couple of questions i wanted to clear up before I move forward.
1. I used TWRP to root my phone, I would like to stick with that but have no issues using odin and running CWR, but I wanted to ask aycjay95 what version TWRP did you use and how did you over come the issues with v 0.1.2.
2. Right now I do not want to use extSD2internalSD should i delete the script before and rezip the build or just delete the script after complete flash?
3. I have seen a couple mixed comments about battery life... is there a clear answer out there about this.
I want to say thanks to everyone working on this and putting your time and effort into this phone, it is a great phone not getting much attention by many Devs.
