I use SwiftKey with no issue. Uninstall and reinstall should fix. I had same issue and I think it's due to the internal and external sdcards being swapped.
For some reason I still always have to reinstall the language pack after every boot. This never happened before I flashed victorious. It's not that big of a deal because 99 percent of the time I have 3g to download it.
Love the rom Jerry! it's been working like a charm ;] unfortunately, for whatever reason I can no longer use s-voice (well, the double-tap on the home button doesnt work anyway). Has anyone else had this issue?
Ok if anyone wants to restore the Self Service Agent so you can update Prl and Data Profile on Victorious Rom it's just a matter of putting these 2 files back into /system/app.
SprintDM.apk - http://db.tt/3F0NTWoN
SprintSyncMLSvc.apk - http://db.tt/XgZJEqtz
Download the files, copy over to /system/app, set permission to match other system apps, reboot and you should be in business.
* You will go back to getting the "Preparing Network" notification whenever you change between 3g and 4g
hey guys just asking for your opinions would this method http://androidforums.com/virgin-mob...2-apps-sd-other-space-saving-awesomeness.html be more efficient than the swap created with this rom or does the swap method cover all the things this does ?
Great stuff, definitely helping in my phone to feel like stock Android. Though I seem to have an issue: wifi tether never asks for SU permission, and just crashes when I try to activate it. Any idea?
edit: also another minor issue, but the boot screen looks completely messed up. I get the Sprint logo, then two garbled Android logos side by side. The ROM works completely fine otherwise.
edit2: anyone know if it's safe to do a boot-time password encrypt on the device, and retain the ability to flash ROM updates?
I have Victorious-0.1.2 installed with Link2SD and some symbolic links set up. If I update do I need to uninstall these apps first beforehand or can I just update over my setup?
And is there a way to get the original stock Samsung boot animation back? I don't care for the Virgin Mobile one, but I kinda liked the Samsung one.
Thanks again for all your help! I've been super busy with work lately, but I will be on here more often and am always trying to keep up with and test new things. I teach computer certs, so it kinda goes with the territory that I love to explore new tech and apps.
One more thing also, I just noticed that gtalk is gone as well. I can install it back myself as I have everything backed up already, but just thought I would mention it. Gtalk was updated to hangouts and having it as a system app has protected it from being updated and lost. I use gtalk at work to communicate with staff when I am teaching or out of the office.
Thanks again for everything. I am glad to post the logcats if they are still of any use... maybe if I get some free time I will break my phone activation again and record it for you if I have to! lol.. I'm sure it can wait for the next update though![]()
