Unknown app messing up my MotoG screen
- By AugieTN
- Apps & Games
- 5 Replies
I would definitely try a factory reset
I think you are correct. I used delete all updates for the Contacts app and the unwanted boxes have gone.So most likely the contacts app was updated and now shows those boxes you are seeing.
You can always install a different contacts app that doesn't show that, but I doubt you can change the contacts app you already have
Check if you are able to disable the Message app from Settings.As the title states, i am in search of a method to disable receiving SMS messages. I want to be able to turn it back on when the need arises too.
Basically, i want calls and such to work, and all the functions of the phone to work, i just want to disable the ability to receive SMS messages temporarily.
I am willing to buy a phone. I guess you missed my post where I said I'd offered to pay for an Android work phone and was rejected. I just don't want to carry two phones, did that for a year and it's a hassle. And I don't like iphones but I guess I'll learn to live with it.Since you're not willing to just buy your own phone, trying to force a work-supplied phone to be both a work and a personal phone requires a good amount of effort on your end as far as endearing yourself more to the administration and the IT staff.
Most universities have understaffed IT departments that need to maintain a lot of oversight over a large number of devices. This involves a lot of restrictions and limitations to keep private matters private, along with staff and user data isolated and secured.
Some users gripe and complain that they can't use those devices for personal usage with expectations that they're entitled to do what they want them, without taking any responsibility when they might inadvertently introduce some random exploit or compromise into the University's internal network. If people where to be made personally responsible financially for their own actions, that would reduce some of that entitlement attitude.-- there's a distinction between allowing some ransomware disaster into a network because of some clever social engineering hack or someone browsing through their personal Instagram account or whatever. The former is work-related matter, the latter is not.
is it the same app? maybe try moving that app on the screen to somewhere the fingerprint reader is.I use an Oppo Find X5 Pro.
I don't think it's adware.
It's my finger on the screen after using fingerprint unlock.
sorry i hate to say it but those text messages are gone....especially from a phone that was made in 2010.
as far as adding apps manually, you can do it via adb. but, most apps probably will not work on such an old phone.
It's not a voice remote. It is a remote on my steering wheel that can be used to control the headunit and also it has a voice command button that transmits the voice command to the headunit but it goes to google search. I would like to press the voice button of this remote and speak a command like "Hey Google play Car playlist on Youtube" and it plays that playlistLooking through that Amazon link you posted, apparently your head unit includes its own, plug-in microphone. Is there reason as to why you also have an additional, external voice remote?
