Help Bad - shallow in game sound
FYI looks like the same apparent issue is documented here as well...
https://www.sammobile.com/news/galaxy-z-flip-3-z-fold-3-one-ui-4-0-audio-bug/
Maybe grounds for a class action lawsuit? Good luck!
FWIW I have a Note20 Ultra myself, and the audio on that is OK for phone speakers. If I want to listen to things in HiFi, I use proper speakers or headphones.
well on my z fold 3, the audio has been pretty good......especially when i play games........no complaints from me.
Help Sound Assistant
How does separate app sound in sound assistant work? When u tap on the Bluetooth icon for one device it sometimes works as it should, and switches media from that app to BT speaker and leaves others to play on the phone. But now, most of the time it takes both app sounds to BT device or to device sound, it doesn't separate it.
Help Need help syncing Google Contacts to a Fire tablet
@JohnJSal
I have the same ptoblem. I loaded Google play store (and its supporting APKs) and can install apps from the Play Store. Gmail works fine with my Google account. Contacts says there are no contacts (there are actually hundreds).
I had the same SMS permission error, so I checked and the SMS permission was set. I removed it, rebooted, and then set it again. The error has gone away but the contacts still do not sync.
The contacts sync fine on my Android phone but not on the Fire HD tablet.
I would appreciate any advice on how to get contacts to sync!
Google telling me what to do again (call recording)
Well Total Call Recorder doesn't work either. Stupid Google. I'm in the UK and there is no law against me recording calls, why are they doing this?
"As an individual you are able to record phone calls. There are currently no UK laws prohibiting actually recording the call – just what you do with the information when you have captured it. The only time call recording becomes illegal is if you hand over the information to a third party without the customer who has been recorded’s consent. You also need to be mindful of how secure the connection is if there is going to be sensitive information discussed."
https://www.numbersupermarket.co.uk/call-recording-laws-uk/
New S9 can send/receive texts (SMS) but not text pix (MMS)
Some providers have different APNs for MMS and for other mobile data, though I know nothing about this particular carrier.
So are u saying that the phone might need 2 different APNs, 1 for internet and 1 for MMS? If so, I haven't found any other information about Page Plus using that type of setup. I also haven't found any APNs that work w/ MMS.
This (doesn't) suck(s)
That's what happened with my pedestal sink. My helper answered the door, and the FedEx driver actually pointed out to her that it sounded like broken glass(?) in the box; he showed her a damaged area and recommended just refusing it as damaged. That's what we did, then received a nice new replacement.
That's what I'd like to know! I've been a loyal Chewy customer for years now, with monthly auto-ships, but I had no idea they sold vacuum cleaners! :thinking:
https://www.chewy.com/b/vacuums-ste...t vacuums & steam cleaners&ref=searchRedirect
It's curtains
I had to put some drapes up on plasterboard/drywall once. I fixed a wooden batten securely screwed into the studding, and then fixed the curtain rail to the batten.
When I was an line-engineer for British Telecom, we often had to fix telephone sockets to plasterboard, which are lightweight things. But we used proper plasterboard fixing plugs and screws...
I have used those things, and even the winged things you fold together, push through, (the wings expand then) and tighten the screw.
They will work, but they are temporary at best.
And very weak, as the drywall must first be damaged to use any of them.
They then expand and/or clamp into/behind the drywall that has been weakend with a hole.
Going into the studs is the only proper and reliable way.
Android 11 tool bar of contacts in Contacts app hides behind freeform window decorations
I also have the same situation! Did you find the answer?
Yes, after digging into the AOSP, I found a fix. I don't think there's anything related to this topic online so I will post here for anyone who has the same issue.
The cause is the "QuickContactActivity.java" does not set a default "isOverlayWithDecorCaptionEnabled" on creation. It should be set to false by calling "setOverlayWithDecorCaptionEnabled(false)" in onCreate, so that the decorcaption, i.e. the title bar on top of the window, pushes the content of down instead of overlaying on the content. After adding this one line, the problem was fixed for me.
I am working on a particular device in our company, but I imagine this could apply to all android 11 devices.
What app is this from?
Very rarely are people asking about notifications on their own phone. What usually lies behind these questions (apologies to the OP if this is not their situation) is that their partner sends them a screenshot, they see a notification on it they don't recognise and, for whatever reason, they can't live without knowing what it is and aren't able to just ask.
If it's your own phone you just pull the notifications down and you can see what it is.
Help Why do only some pictures transfer from Samsung Galaxy S7 to laptop?
Hey, to transfer all photos on your Samsung Galaxy S7 to laptop, my suggestion is Coolmuster Android Backup Manager. Its backup function can help you transfer all photos from your phone to the computer via USB cable directly. And it's free. And you can also use Dropbox, Bluetooth, etc. to help you do that. About the details, please search online. Hope this will be your help.
How Do I stop google uploading My Information?
He means when you add a contact you can either choose to sync with Google (or various other accounts such as Microsoft Exchange, Samsung Account, etc) or save it as a 'phone' only contact meaning it does not sync or backup the details. It'd be a local only contact and if you lost the phone or busted it, that data would be lost.
I've saved contacts as phone only since my Nokia 5185i days. It's just a habit I refuse to break, much like keeping my music on an SD Card, and avoiding anything mentioning the 'cloud' or 'subscription'
RocketSpaceChallenge
I love games resembling Moon or Jupiter Lander (from my old C-64). I tried your game and graphics are OK but controls seem to be too fast to move the ship. Also, gas is not enough sometimes for the first levels (with the moving barriers) making it really hard to win (specially with the super sensible controls). Good concept though. Keep up the good work. Cheers.
*#*#checkin#*#*
"Moaziz Sarif, Google Direct Carrier Billing k sath ab hamaray Android Data customer Google Play Apps, aur pasandeeda Android Apps khareed saktay hain. Sath he sath apni pasandeeda google service ko apna ZONG ka balance istemal kertay huay subscribe ker saktay hain, bagher kisi izafi tax kay.
Daily limit: 10,000 Rupay
Monthly limit: 20,000 Rupay. "
Shikayat k liye Google Support par rabta karain (support.google.com/googleplay)
Zong billing check karny k liye dial karein *#*#2432546#*#* ya visit karein (https://androidforums.com/threads/checkin.38801/) plz sir pubg lite bc add
Filter
