Microprocessor/wifi
Very frustrating because. She was paying off that phone. It took over a year to pay that phone off. While she was paying it off the phone worked fine. Then it seems shortly after she paid it off in full this wifi issue started.
yeah, this is why i always have insurance on my phones. i usually get my phones from BestBuy and i always make sure i have Geek Squad protection on it.
Change lock screen time
Initially I thought it wasn't what I wanted as it's an AOD, which I don't want.
|I installed it and realised there are a lot of settings, including a timeout to set the app to sleep - i.e. the screen is off. In the end it does what I was hoping for, and I can set the clock to turn off after a time of my choosing.
Thanks for posting the app details.
Glad we can help. You are welcome to stay in here forever.
Has youtube gone back to the old miniplayer?
I’m so relieved YouTube switched back to the old miniplayer! The new one was really annoying with its size and position constantly changing. I even had to call the youtube phone number to sort out a couple of problems. IMHO, the old miniplayer is much easier to use.
Had no idea about such a url ever existed,most of the times I just do not worry about something so small.
The Galaxy S25 Pre-Release Thread
Unpacked is LIVE!
Admittedly, the new AI Assistant is impressive... and personal data stays ON THE DEVICE. Yes, the S-Pen is losing its Bluetooth capabilities. However, Samsung noted that fewer than 1% of all users even bothered with those capabilities. While I have long used the S-Pen button as a remote shutter, I can now do the same thing with the Camera Controller on my Galaxy Watch Ultra.
Out look app..
For Anyones wondering, I downloaded a windows app, that turned off the tags by accident Easily duplicate, I log into my account, and told me to highlight and copy the code, and made the tags into it, files, right click them on my outlook and deleted them.
Multiple Contacts on Phone
Believe me, I'm no expert! But what I did discover in trying to solve my problem is that the menus are a bit confusing insofar as they don't tell you that there are sub menus that you can drill down to. I drilled down three or four levels and finally discovered a button that says "sync account" or not. I started unsyncing everything other than my exchange account and was able to lose the multiple duplicate contacts that were caused by having numerous accounts synced. Including accounts for Samsung, WhatsApp, etc. Each one imported a copy of the contact data, much of which was outdated.
Maybe you can disconnect by unsyncing your accounts?
I somehow discovered by downloading a file eraser, I went away and just as soon as the contacts where lingering on it, still the clone numbers on the outlook, turned to files of where I just right click to clear off the numbers, and it works! By accident.
OnePlus 13 and 13R
Well, this phone is going back. Unbelievable that some basic Android software features have been reduced or eliminated. To save memory?
The direct dial widgets were eliminated entirely. And the notes field in Contacts now has a maximum number of characters, so most of my notes can't even migrate. Plus the account settings are like trying to read chinese! Oh wait, nevermind.
RMA in hand!
Hello Galaxy S25!
Battery draining quicker than usual on Samsung A02
Milo seems like a friendly fellow which is great.
However I am here purely for Technical information and feedback.
Battery still drains in just a couple of days.
It is ok. I decided to save up to buy a new phone. The current phone hopefully will last until then.
Consider the subject / Thread closed.
Milo doesn't know dick about phones. He, much like my wife, just fakes it.
Filter
