Edittext skipped
- By Unforgiven
- Android Development
- 1 Replies
I added code tags to your post for readability. Good luck!!
Help Android and Samsung Pros:
I have two Samsung A11 phones through Straighttalk and and a Samsung S5 that shouldn't have cell service. My cellular wireless signal is automatically connecting with incomming harassing people. (Its a criminal back door). Does anyone know how to shut down the antennas on the boot?
I am a root on the S5 phone. It may be some sort of secret service mode being used for criminal purposes. Wifi and airplane mode have no effect. How do I cut these guys off? Erase all of their software.. it's a hidden connection.Thank you. J Carver
Your Moto's integral phone call log will be stored in a directory you don't typically have direct access to, so it's not something just any file manager app can access (there are a lot of restricted files/folders on your device that are protected for specific reasons). You might want to use the SMS Backup & Restore app:
https://play.google.com/store/apps/details?id=com.riteshsahu.SMSBackupRestore&hl=en_US&gl=US
As its name implies, it is primarily a utility to backup/restore SMS text messages, but it also includes the ability to save your phone call log as a separate xml/txt file.
OP figured it out after posting.I discovered the solution after posting this issue.
do you have a sd card? are you trying to write on the system partition? or onto the sd carrd? what file manager are you using?
Well you'll still need to do what gets explained on that site (sequence of steps using the indicated buttons) in order to get into your phone's Recovery. Whether you do or don't actually connect your phone to a PC to use that indicated utility isn't a requirement. Your posted query referred to Recovery Mode for your particular phone, focus on that instead.The tutorial has received a rating of just 1.3 and following it would require disabling virus protection on computer so I'm not going to try it out.
Thanks anyway.
