Post Your Purchase Deals Here
- By Steven58
- Smartphones
- 1 Replies
I got new phones for my children using that deal. You're right. It's great!
@puppykickr @mikedt bro thank do u know any old version or old app for 3rd party dialer which can work with Android 5.1The last Android 5.1 device I had was five years ago, an Oppo Find7. So have no real ideas about it these days. Except to say that devs very likely no longer support it, and it's probably only going to run older versions of apps, that's it.
, but it's not something that the user uses to send data anywhere.It seems Sound Assistant is a separate set of options that got added into Android 11, because it has the separate app sound option. However, that will only work for one app at a time, and is the app's output sound, not notification alerts or any of that.I know Samsung phones with Android 11 can do that, like the Note20 and S21, via a feature in Settings called "Separate app sound", which allows you to set app notifications to only go through the BT headphones or the phone's internal speaker.
Samsungs with Android 10 I don't know, and I've never heard of this "Samsung Sound Assistant" ether. Is that a feature of the S9 phone?
Will do. Thank youCheck whether your device was set up with Samsung’s speech to text instead of Google’s speech to text at first. A friend tried using the Samsung one but it was just not as good as the Google one.
hmmm... Thanks for the heads up.No it won't. This is one aspect of Android 12 theming that doesn't get influenced by your wallpaper. It strictly follows the Light/Dark theme option as selected by the user.
nope do not use it, sorry. just post here if you are having issues. if i can't answer right away, i'm sure others here can help.thanks I appreciate it. Do you have whatsapp so we can talk incase it fails?
Google = the walking dead without being a zombie, only a better zombie..Well, I tried reposting the review with a few edits (including deleted parentheses) under my main account (instead of a different account), after changing my main account's name so it doesn't show my legal name.
This time it got posted. I don't know if it was due to the edits or which account I used.
Google loves to shadow-hide content it falsely indicates is published, and is not transparent as to why perfectly valid content is shadow-hidden.
Translation:Tatsächlich ist nach einem Neustart die Nutzung des eingeschränkten Nutzer erst möglich, wenn der Hauptnutzer alles entsperrt hat. Wenn das Gerät im Stand-By ist, dann kann der andere Nutzer direkt darauf zugreifen, jedoch nicht nach einem Neustart. Das kann im System auch nicht geändert werden
In fact, after a restart, the restricted user can only use it once the main user has unlocked everything. If the device is in stand-by, the other user can access it directly, but not after a restart. This cannot be changed in the system either
Translation:Das ist auf jeden Fall bei Samsung immer der Fall, ob es aber komplett Android-spezifisch ist, kann ich dir nicht sagen.
This is definitely always the case with Samsung, but I cannot tell you whether it is completely Android-specific.
