Samsung Fold5 & Flip5-One UI 6.0 stable roll-out
Samsung have just released their stable One UI 6.0, Android 14, update, BWKA, for Fold5 UK/European users on the international model, F946B, along with the November security patch.
Build = F946BXXU1BWKA
Download = 451.69MB (this is the d/l size for existing Beta users)
Build date = 13 November 2023
Camera version = 14.0.00.46
Security patch = 01 November 2023
It is a FOTA, (Firmware Over The Air), update and you can check... Settings > Software update... to see if it is available for you. Alternatively, you can connect to the Samsung PC suite, Smart Switch and check via that.
Restoring Note 8 from Factory Reset - SD Card: 'ready to transfer media files'
I've no idea what "ready to transfer media files" means, I'm afraid.
You and me, both. I did click one entry and it restored a Samsung Note to the Notes app.
Are you hoping to recover some of the apps you "moved", or have you just reinstalled them all and are planning to "move" them again? It's not completely clear from your post which is the case, and I've never heard of App Manager III so don't know for sure what it does.
I have restored many apps from the Play Store and after many hours have an almost? completely functioning phone. Photos, apps, most notes, --things are looking good.
When I do open an app, I must log in like it was the first time, but that's not too bad.
But unless your phone is rooted I have to assume it's just using the Android 2 style "move to SD" function, and as that only moves part of the installed app if that is what it's done you'll almost certainly have to just reinstall from scratch anyway
not rooted. reinstalling apps, ;)
Stuff like documents, music, DCIM on the SD card can just be left there. If you want camera images stored on the SD card you may need to change the camera app settings to tell it to write there as it's not the default - unless some of your settings were saved to some cloud account ad hence restored when you logged in again.
Stuff in the "android" folder is specific to the particular apps (all that "com.whatever" stuff is the actual package names for various apps). Many of those folders will actually be empty anyway, for others, maybe just try reinstalling the app and see whether it finds them? I've not had a removable card since Android 5 so don't know for sure how this will behave - I have such folders in my internal storage instead. But if there is anything particularly important there (e.g. WhatsApp backup and media folders) maybe take a copy for security before doing anything.
Will do. This has re-convinced me of the importance of backups. The first layer will be a SmartSwitch backup once I can run it.
Thanks for your input.
Luggage tracker
I'll wait until an android-wide tracker is available. [...] If Google ever release something and integrate it with Find My Device then they'll have the biggest network of the lot.
Seems Cihpo has you covered, they have trackers which work with Google's "Find My Device" for pre-order. I contracted Cihpo support to make sure I understood the page properly, and here's what they had to say:
Yes, every compatible phone (almost all recent Android phones) will be a part of Google's [Find My Device] network. You will be able to get an updated location whenever the Chipolo Point tracker will get in range of a such device.
This link (my affiliate link), according to Chipolo, gives a 20% discount. Just make sure you order the Chipolo trackers for Google's network! They also make trackers for Apple's network, and their own network.
Pet Foods
i know some people who have their dogs on a raw meat diet. not sure what cuts of meat they get, but it does sound more expensive.
The concept of creating dog food with flavors like sirloin or filet mignon is primarily a marketing strategy aimed at appealing to pet owners rather than the dogs themselves. Dogs do not have the same nuanced taste preferences as humans, and their primary considerations are usually based on smell and texture.
While dogs do have taste buds and can distinguish between different flavors, their palates are not as complex as those of humans. They are more attracted to the smell of food rather than the specific flavors. The use of terms like sirloin or filet mignon in dog food branding is meant to suggest high quality or gourmet ingredients to pet owners who may be more likely to purchase such products.
Samsung S21-One UI 6.0, Android 14 rolling out
Samsung have begun the roll-out of the stable Android 14, One UI 6.0 release. First to receive it are the international devices, G9**B.
Software information
Samsung S23 camera - RAW is so restricted (PRO mode only?)
I did actually find the auto exposure options in the factory camera app, in the PRO mode.
Not sure they work correctly, or usefully. But better than nothing. Now I need to sort out why the PRO mode gets auto cancelled after a while.
I was puzzled when you said that Pro mode didn't do AE, because it clearly does. Of course it mislabels the exposure compensation feature as "EV", which are the units you adjust exposure in but as such both the actual (auto) exposure and any compensation you apply are both in EV and so it's a poor choice of label (if they employed any photographers in their camera team they'd know there is a standard exposure compensation symbol).
Chicken Flavored Potato Chips
Wife picked these up. They are from Canada.I first tried chicken flavored potato chips in France, and they were the best flavored potato chip I have ever tried. Why Lays hasn't brought this flavor to the states is beyond me. They are delicious.
I'm still trying to figure out the chicken 'n waffles thing and you want me to give these a go? ;) :D
No Root Firewall
I'd start by looking at Settings > Apps > No Root Firewall and seeing whether there is a battery setting in there. If not, try searching the settings.
I'm being imprecise because settings change with both android version and manufacturer, so not knowing what phone we are talking about means it's impossible to say where the setting will be (e.g. I'm using a Galaxy s21, and Samsung are about the worst of the lot for rearranging the Settings in their own way).
Getting Multiple Gmail Notifications for each Message
A Samsung account is a different thing from a Google account, though it may use the same email address. So having that account associated with the same GMail address doesn't mean that it is receiving your GMails.
And all android phones will have a Google account, even if they don't use the GMail app. So that one is also a red herring (and don't remove it, because that is the one your contacts etc will be stored with, as well as your Play Store account).
Are you receiving multiple notifications as well as multiple tones? Because if other email apps were receiving the messages you should get separate notifications from them, and be able to read the same email in all of them. And when you changed your tone in the GMail app did all of the multiple tones change? If they did then that would suggest that it's the GMail app generating multiple tones rather than different apps doing this. I can only suggest checking the GMail app's settings (including making sure it doesn't have something screwy like the same account synced multiple times - something I've never heard of and wouldn't have guessed possible, but we're dealing with something screwy here so why rule anything out?). Unfortunately I don't use that app myself (it's disabled in fact) so am not familiar with its settings.
I am confused about my "almost" rooted phone.
I did "format data" and it didn't work.
Then, I factory reset after I found out that it didn't work.
you are going to have to flash a firmware update(stock rom) and start over.
[Game][App] Embark on an Epic Adventure - Drake's Quest: Looted Lore
Greetings, fellow gamers!
I'm thrilled to introduce my second 2D platformer game that will take you on an unforgettable journey—"Drake's Quest: Looted Lore." Join a fiery protagonist, Drake the dragon, on a mission of epic proportions!
The Story Unveiled: In the heart of the beloved village lies a precious treasure chest, the lifeline of this community. But, Villainous enemies have looted this chest, plunging their village into despair. Fear not, for Drake has been chosen to reclaim what is rightfully their!
Explore Enchanting Jungles: Navigate through lush, vibrant jungles that are teeming with life and danger. Each step is a leap into the unknown, with hidden traps and challenges awaiting the intrepid Drake.
Run, Jump, and Fly: Experience the thrill of dynamic gameplay as Drake showcases his agility and strength. Run through obstacle-laden terrains, leap over treacherous traps, and spread your wings to soar above the challenges that lie below.
Engage in Fierce Battles : Drake is not just a nimble navigator; he's a formidable fighter too! Confront a variety of enemies, from small but cunning attackers to powerful adversaries. Unleash Drake's fiery breath and master combat tactics to emerge victorious.
Immersive Gaming Experience: Engaging storyline, captivating graphics, and a melodious soundtrack will keep you hooked from the very beginning.
. Why "Drake's Quest: Looted Lore"?
  • Unique dragon protagonist
  • Challenging levels and cunning enemies
  • Stunning visuals and atmospheric music
  • A blend of exploration, platforming, and combat
  • Hours of gameplay and endless adventure
Available Now On Google Play Store:
Don't miss out on the excitement! Grab your controller, buckle up, and let the quest begin!
[This game is available for all because it's in the production]
Filter
