Problem with moving sms
It really shouldn't happen, because the SMS app is just a front end, they all connect to the same message database and use the same messaging service. You have given Next SMS permission to access your contacts? Though that shouldn't stop the messages displaying, it would just stop it showing names for the sender.
Otherwise all I can think of is to force Next SMS to resynch with the message database. Textra actually has an option for that, but that's unusual, so you may have to clear data for Next SMS to force it to restart (which will unfortunately remove any customisations you've made). And I don't guarantee success, this is just the only guess I have.
Help CANNOT ACCESS ANYTHING-JUNK
Just throwing out an opinion here .. I don't use privacy or encryption messengers for the same reason I don't use password managers, I just don't like the idea of handing out my personal data and secrets to an app that was written by faceless people with unknown integrity. Much safer, and just as easy, to encrypt text first and just send it via standard text app or email.
AZ Screen Recorder Video - Audio and Video Not in Sync
Thanks much for your reply. Unfortunately, the download using AZ Screen Recorder only produces 1 file of a video on this particular site in which the video and audio is not in sync. Is there any workaround?
Sure is.
Use the screen recorder I mentioned above, and re-record it.
Sorry, but this is the easiest method.
Another is to extract the audio from the file you already have, then try to sync the two files together using YouCut.
Use this app to extract the audio.
https://f-droid.org/en/packages/protect.videoeditor/
How To Move Picture Albums to SD Card
Here is the cool part of what I suggested above.
File Manager Pro allows for simple movement and renaming of files, very much as you do with a stock android device app- but better.
Gallery Pro also allows you to do this, but in a gallery format for easier viewing.
You can access both the internal memory and the SD card seamlessly, unlike with a file manager.
Select your photo, select 'move', it will show you all available folders, choose and tap.
Done.
Together, they work great, as you may someday find a file tgat doesn't outright appear in the gallery.
It will show in the file manager.
Now, as for Nitroshare, simply install it onto all of your devices- PC included.
Set it up, and now you can send files wirelessly and quickly via Wi-Fi to any device on the same Wi-Fi that you have installed Nitroshare.
It doesn't get much easier than this.
[App][4.0+][Free] Resistor Code Calculator
Hi everyone,
I am engineer, I know that reading resistor value is small task but you have to do many time.
It will waste your time, make your stress.
So, to make you have more free time and power to optimize your projects, I make this tool.
Let build more awesome projects and gain better life.
Feature:
- This app help you read 3, 4, 5, 6 color bands resistor value.
- Auto hide/show color band relative position, easy to pick color left to right
- Fast color pick method with full size board
- Show ohm value range base on tolerance (+-%)
You can get it on CH Play:
https://play.google.com/store/apps/details?id=com.hamatim.resistorcalculator
App Inventor Android studio - java - mysql connection
Hello! I am trying to make a simple connection to my database, but for some reason I just can't do it? I have followed tutorials, such as:
or https://parallelcodes.com/android-connect-mysql-database/
My issue is that once I insert the class.formane(com.mysql.blabalba), my app just crashes?
Is there anyone that could help me please? I really don't understand why my app doesn't want to function...
Browser display problem, double windows????
Hi all! I'm running an R99 Android 6.0.1 TV box, and in all browsers (Chrome and Chrome Beta) I am getting a double window where the top of the address bar is overlaying what appears to be a "second" window beneath it, which has the browser tabs on it. About half of the tab is covered so you can only see about half of the tab vertically. You can't see the X to close the tab or the + to add a new tab. This is extremely hard to manage with an air mouse pointer. You can very carefully aim and close tabs by hitting where the spot should be at. However there does not appear to be any way to close this overlaid "double window". I use Chrome and Chrome Beta regularly on my phone and have never seen this before. All other apps display normally with no double windowing or cutting off, so it looks like my device display settings are OK. What might be the problem?
That is how the main OS for all my android phones are, just relax and clear the cookies :) Nothing of a huge issue.
Mxq Pro 4k
I have an mxq pro 4k that was connected to a crt tv via rca which I used for a long time with no issues. I got a new 4k samsung tv(hdmi) and when I connect it it plays for a while then the sound suddenly stops while video plays. I tried with RCA connections and it does the same. Any idea what could be the cause of this. I have tried changing multiple settings but no joy.
Filter
