Missing Pictures
Thanks for the response. I am not using Google or anything for a backup yet, as I just got the phone and haven't set everything up. I will probably sync with Onedrive as my backup so going forward it will be fine, and the pictures I lost weren't important, but still a little unhappy that my brand new phone, at the price point of an S20 Plus, has that kind of a major issue right out of the gate. :(
I am trying to view the pictures in the gallery that is on the phone.
can you view the photos if you hook up the phone to a computer?
Help How to stop Android 9 switching between wifi networks
OK, so it is a matter where you need both WiFi networks from your primary router and your Invizbox router, depending on need. And since it presumably sounds like both routers are emitting signal strength in more or less equal measures, depending on where you are in your household, that's also an issue since any 'strongest signal' solution isn't going to work out. Sadly the manual connect setting in your Huawei isn't being observed (????) as that should be just what you need for this situation.
Just an offhand suggestion but there's an app called Tasker that you can use to set up automated tasks, in your case manually select which WiFi network to connect with.
https://play.google.com/store/apps/details?id=net.dinglisch.android.taskerm
https://www.androidpolice.com/2020/...ow-to-automate-almost-anything-on-your-phone/
Here's an example of what someone in a similar situation posted on the Tasker forums:
https://forum.joaoapps.com/index.ph...phone-tries-to-connect-to-other-networks.164/
[Free][Game]Beat the Best - action-packed 3d endless runner game
I have finally programmed my first Android game "Beat the Best" (3 months development) and would like to introduce it to you here. It is a 3d endless runner game with simple controls and great features. It can be downloaded free of charge from the Google Play Store using the following link: https://play.google.com/store/apps/details?id=de.DHenningt.Beat_the_Best
Apps Android Studio, Butterknife and error on static methods (Androix X)
I am making a project of connecting to the star wars api, getting json object replies and presenting them on my View through recycleView (in short). However i am getting erros on build project through my gradle file (here in its entirety) :
apply plugin: 'com.android.application'
android {
// Configure only for each module that uses Java 8
// language features (either in its source code or
// through dependencies).
compileOptions {
coreLibraryDesugaringEnabled true
sourceCompatibility JavaVersion.VERSION_1_8
targetCompatibility JavaVersion.VERSION_1_8
compileSdkVersion 28
buildToolsVersion "27.0.3"
defaultConfig {
applicationId "com.juangm.bottomnavigationmvp"
minSdkVersion 26
targetSdkVersion 28
versionCode 1
versionName "1.0"
testInstrumentationRunner "android.support.test.runner.AndroidJUnitRunner"
buildTypes {
release {
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'
dependencies {
compile fileTree(dir: 'libs', include: ['*.jar'])
androidTestImplementation 'androidx.test.espresso:espresso-core:3.1.0'
androidTestImplementation 'androidx.test:runner:1.1.0'
androidTestImplementation 'androidx.test:rules:1.1.0'
compile 'com.android.support:appcompat-v7:28.3.1'
compile 'com.android.support:cardview-v7:28.3.1'
compile 'com.android.support.constraint:constraint-layout:1.1.3'
compile 'com.android.support:design:28.3.1'
compile 'com.android.support:support-v4:28.3.1'
testCompile 'junit:junit:4.12'
compile 'com.jakewharton:butterknife:8.3.2'
coreLibraryDesugaring 'com.android.tools:desugar_jdk_libs:1.0.5'
implementation 'com.jakewharton:butterknife-compiler:8.1.0'
compile 'com.squareup.retrofit2:retrofit:2.5.0'
compile 'com.squareup.retrofit2:converter-gson:2.5.0'
compile 'com.squareup.okhttp3:okhttp:3.12.0'
compile 'com.squareup.okhttp3:logging-interceptor:3.8.1'
compile 'com.fasterxml.jackson.core:jackson-annotations:2.7.3'
compile 'com.android.support:support-annotations:28.0.0'
implementation 'com.android.support:recyclerview-v7:28.1.1
The error i am getting : **Static interface methods are only supported starting with Android N (--min-api 24): void butterknife.Unbinder.lambda$static$0() Stack trace: **
As you can see, i have already added the compile options for JAVA.version 1_8 on the gradle, but it does not seem to solve the problem.
Any help is appreciated...​
How can I get apps?
Being connected to Wi-Fi and having internet are not the same thing, although a Wi-Fi network makes internet access much easier. However, as @Hadron points out: if the router you're connected with isn't connected to internet OR it isn't giving your device access to it, then it's like connecting a garden hose to a faucet and turning the handle - but unless that faucet is connected to the water supply, you ain't gettin' water. Try a different Wi-Fi network somewhere and see if that helps.
Android 10
Somehow it seems like you may be tapping something too slowly, or in the wrong place, when switching apps... and the phone thinks you're trying to select an app for multi-window (which would put one app in top or bottom half of the screen, allowing a second app in the other half).
Try going to Settings -- Notifications -- Overflow Menu (three dots upper right) and select Show system apps -- System UI and making sure that if notifications are turned on, Multi window is turned OFF. Back out and try it again. Let us know if that stops the pesky notifications.
Amber Alerts on Samsung A5 (2017)
On my Verizon phone, this is How to turn off Amber Alerts on the Galaxy S7 Edge: 1. Swipe up or down to display the gear icon to access SETTINGS 2.Navigate SETTINGS > CONNECTIONS> MORE CONNECTIONS SETTINGS (way at the bottom) 3.Tap EMERGENCY ALERTS 4.Tap the 3 dots in the upper right, then tap Settings 5.Tap ALERT TYPES 6. Select any of the alert types and turn off.
Yeh, my S7(bought in the UK) doesn't have that. So it must be something that's only in carrier version S7s in the US?
my wifi mac address changed after reboot
AFAIK it is the same feature, although the actual methods used might be different, Android uses Linux kernel, and Windows 10...not a clue.
I'm sure all comparatively recent OSs have it, Android, Windows, Linux, MacOS, iOS, etc. As for Android 4.1, could be something the device manufacturer implemented on their own?
From the previously posted URL:
MAC randomization prevents listeners from using MAC addresses to build a history of device activity, thus increasing user privacy.
Hi I think this is implemented my device manufacturer. My wifi mac changes every time when I power on my device in stock os. Despite that, my bluetooth hardware address remains constant.
Help Trying to get all my data from LG -X410ASR to Viking Pro 2-in1
Hi folks, it's me again,
So I got fed up with that tablet, took it back and got another MUCH better Android, but version 9, same as my phone and after all that figured out how to transfer data through my Bluetooth....the other didn't have it I think, but.....now another issue...
I have 32GB storage on tablet and 32 SD card, so, plenty of room. The issue I'm having, I've Googled til I'm blue in the face and eyes foggy....I noticed that after I had installed all my usual apps, then put the shortcuts on the home screens, some were just disappearing...so after going through putting them back, stopped using the APKPure, and using Launcher3 (still not too sure why either is needed), it still happened. Then I realized it's ONLY apps that are stored on the SD card (I have it as default to save internal space).
I am beyond irritated now 🤔but read to try re-mounting the SD card then re-adding the apps, then rebooting the tablet.....all I can say now is :
#$&(%*$# (insert expletives!)
Can you help? I'm hoping this is some simple setting, because having to re-add the apps to the home screen every time I reboot it, is ridiculously stupid, and a pain in the a$$!!
Thanks, Diana
***Not to mention, my mind is pretty much out there right now, because I just lost my 14 1/2 year old furbaby, in a totally freak accident, who my son rescued at 6 months old, who was also my heart, my best friend and my world :(....
Can't find Emergency alerts settings
On a Verizon phone, this is How to turn off Amber Alerts on the Galaxy S7 Edge: 1. Swipe up or down to display the gear icon to access SETTINGS 2.Navigate SETTINGS > CONNECTIONS> MORE CONNECTIONS SETTINGS (way at the bottom) 3.Tap EMERGENCY ALERTS 4.Tap the 3 dots in the upper right, then tap Settings 5.Tap ALERT TYPES 6. Select any of the alert types and turn off.
Help No emergency alerts setting on my phone?
I got woken up at 3am the other morning by an ear-piercing amber alert after I spent days having insomnia and finally was sleeping. I was beyond enraged. I tried looking all over my phone to find the setting on my Galaxy S7 Edge to turn it off, but NOOOOOOOO, couldn't find it anywhere. I then googled how to do it and read countless articles that kept saying go to this setting or that setting, which did not exist in any of the menus on my Galaxy S7 Edge phone. I then decided to call my carrier, Verizon, and ask them. For anyone going through the same hell, this is How to turn off Amber Alerts on the Galaxy S7 Edge: 1. Swipe up or down to display the gear icon to access SETTINGS 2.Navigate SETTINGS > CONNECTIONS> MORE CONNECTIONS SETTINGS (way at the bottom) 3.Tap EMERGENCY ALERTS 4.Tap the 3 dots in the upper right, then tap Settings 5.Tap ALERT TYPES 6. Select any of the alert types and turn off.
Filter
