'Loading sign' on homescreen, why and how to get rid of?
- By amazijn
- Smartphones
- 2 Replies
Thanks a lot! It worked! You're super!Long-press on it, and drag to the "x" that appears on the top or bottom of your screen, or choose delete...
I could not find that particular setting... But good to know, thank you!On some (all of mine, anyway) devices, there is a setting somewhere in the Battery section of Settings that allows the user to allow the power saver mode to automatically engage at a certain battery level, like 15% or thereabout.
This (on mine) automatically is disabled when the device is connected to a charger, so in that case the setting would be off- but when off the charger the setting will be on.
This can also cause confusion.
Glad to have been of some help.
You need to distinguish apps have different functions and different purposes. An app that only does a singular task will only require it to be running in memory when needed. If it remains partially loaded into memory is a complete nonissue, but the fact is until you actually launch the app it's inert -- it is taking up storage memory space but not RAM. An app like an email client however will need to be running in memory when you are actually using it but in the background to periodically poll your email service's online servers. (and note a lot of email client apps do have settings so they won't check for new messages but that's another issue.) An app that's by design is required to run in the background is different than one that isn't, you can't lump all of them together just out of convenience to make some point.
i would only recommend kingo root if it is the only way to root the device. if there other ways to do it, i always recommend that you do it, the harder way. this way you get to learn skills you would not have learned thru a simple app. plus if something goes wrong anything that you learned could help you troubleshoot the device fairly easily.
its all good....i was not trying to be condescending what so ever. if you thought that, then my apologies. i'm glad that the factory reset worked for you.
i'd give you a high five, but we are supposed to be responsible adults and be socially distant.
here is one anyways:
I don't even pay attention to, or use, the 'follow' feature here. I don't know why, exactly, but it's just unnecessary for me here, whereas on Twitter it's very important.I really don't think followers mean much, tbh.
Okay. As I pointed out, your path may vary, but should be similar to:Yes I tried your instructions and it didn't work. Once my phone updated so many things changed and now I have to learn new ways of doing things.
I found something that had no name, uninstalled it, restarted phone and I think it took care of that popup!
Now to switch cards and test the wifi out! Got to stay more on top of these issues. I rarely used the phone online before, only other issues that I dislike is that if you dont update apps... things start to go haywire!
Question, anyone install Linux on Note3? Or do you recommend another OS? I like to have more control over my phone, mini pc...!
