Galaxy Tab Very Slow on Wakeup
- By Bruce Donald
- Tablets
- 11 Replies
Do try to factory reset but store your data first means backup,
you can't. its only upgradable to android 10. even rooting the phone, you can't upgrade it to android 12.....sorry but you can either deal with what you have or upgrade your phone with a phone that is on android 12.Need Odin files 4 galaxy a7 ans SO Android 12 . I want update galaxy a7 2018 to Android 12
huh? your post is not very clear on the point you are trying to make.Omg.. same issue, started long time ago.. I love this addition everywhere : no solution, nobody responsible, (samsung&google) and shame of you, and why do you want it to work? Like a crazy apple forum...
www.itechfever.com
I'm a poor judge of distance, so I can't answer that first question. I can tell you though that it seems to acquire way points and notify of turns simultaneously with the phone... regardless of whether it's from the phone it's tethered to or the passenger's phone. Interesting (but at least it works).How accurate does it look: accurate to 3-5 meters or to 10s of meters? The former would imply that the phone was passing a GPS location, while the latter is what you get from wireless networks alone.
(Unless Bluetooth is involved somehow? Bluetooth on Android requires location access, so perhaps there's a route for the tablet getting precise location from the phone that way? I'm just speculating here - it's not something that could happen by accident, but I'd not put it past Google building that in without telling anyone, whether via BT or the hotspot)
Thank you for your reply svim. It's good to hear that they cannot reach the files without unlocking the screen. If they can get it charged and make it work that's going to be enough for me for now. At least I'll be able to take my files before it needs another possible repair.Keep in mind that yes your lock screen will block them from being able to access your files, but this also prevents them from being able to confirm their work did or did not work out properly. By intentionally not allowing them to log into your phone to interact with the Settings menu that could be a good loophole on their end to not having to support any kind of service guarantee.
I'd suggest you back up your all your data, and then do a Factory Reset to wipe your user account data. Turn over your phone for servicing, then when you get it back do another Factory Reset (a good practice for whenever you give your phone to someone else outside of your oversight), and then restore your data from your backup. From your wording it doesn't sound like you already have a backup solution in place. Really, that's not a good practice. Don't expect your smartphone to be a good place for long-term file storage. If there's data that's stored only on your phone, that's a big risk you'll eventually lose it. Backups are important.
Thank you for your reply Hadron. If its the norm and file transfer over USB requires unlocking the screen on Kitkat too, then I won't have any problems giving my phone to them. I could find an old phone with Android 2.3, I'll try this on that and if it also requires unlocking the screen before allowing it to connect via USB on 2.3, it's probably like that for Kitkat, too. I'll add the result as a new message here after I test it.I can't remember fine details of KitKat, but the norm for Android is that file transfer over USB requires unlocking the screen.
If the phone won't charge then you can't do much anyway, since you can't change any of its settings, remove any data, or whatever unless you can power it up. So your choice is either to trust them or to buy a replacement battery or USB port (the 2 most obvious reasons why a phone might not charge) and look up how to do it yourself.
I'd almost be more concerned about the opposite problem: if you don't have a backup of those files, are you sure they won't be lost during this repair? Some service centres reset phones as a matter of procedure, so without a backup that would be the end of them. A less official repairer probably won't, but it's something to check. Also bear in mind that if it is the battery or USB port that's faulty then it should be possible to repair this without data loss, but if it's any component that's fixed to the motherboard, or the motherboard itself, then the repair will consist of replacing the motherboard, and as your storage is soldered to that motherboard your data would be lost in that case. If the data are important and you don't have a copy you might want to let them know that they shouldn't do anything that may cause data loss (and of course if anything is important you should always back it up somewhere else: phones break, get lost, get stolen, so keeping the only copy of something important on a phone is never safe).
Thanks for your reply The _Chief. The data isn't something illegal, but it's important. So wiping the device isn't a choice for me. I can't give full access to the repairer neither, as long as he's not going to repair it next to me. I think I'll have to rely on android's screen lock to not allow anyone connect it to a computer with a USB cable. Thank you for the options you've informed me about.There's the problem - OP cannot access the phone to back it up. It's effectively a dead phone with critical data on it.
The problem, @jaarisnow is that the technicians have no idea what components to replace without full access to the entire device and the data stored on it. I don't know why a newer phone can't be used, but I assume you have researched it and have valid reasons.
From my limited perspective, then, I see two options for you... neither of which are good. You can either (a) have a phone repair technician work to recover your data, with full access to it; or (b) consider your data unrecoverable and wipe the device, with a permanent loss of data.
Personally, as a technician, I can assure you that cell phone technicians have seen it all: financial accounts, naked selfies, sex videos, and the most intimate, secret data people have. Unless your data is patently illegal, it's doubtful the technician will even blink at the content.
You can try to find a technician who shares your values and is, perhaps, willing to sign an NDA (Non-Disclosure Agreement) to keep your secrets secret; otherwise, you have very few options.
I don't like being the bearer of bad news: from my perspective, however, that's the best I can offer you.
samsung? google? they all belong to the right side of the force. its when you go with apple, that you find yourself on the dark side.I was hoping we would have lost you to Sammymobile by now
Excellent suggestion.. Consider asking the big guy Suggestions & FeedbackCan we get Google listed back up to Brands and Models? rather than Archived Content?
