What's the best file explorer to replace es file explorer
- By timbr
- VIP Lounge
- 16 Replies
Yes, I also remember security warnings about ES Explorer from some years ago. Interesting it took Google that long to give it the boot.
Yes I just tried rebooting the router. Still the same thing, all my other devices can connect just fine but this Galaxy Tab 2 still doesn't want to connect.have you tried rebooting the router?
OK so we get this question everyday. the problem is that there are millions of apps out there that have notification icons. so unless it is something like facebook or youtube, most of these questions go unanswered. the easiest way is to look on the phone's notifications to see what it is. but as you stated this is not your phone. of course you can just ask, but i guess that is not as easy as it sounds.Clearly it's not my phone or I'd know
I ran into this problem after replacing phone with newer model and using software to move all my apps and data. Discovered the missing setting was to grant the Messenger app permission to Draw Over Other Apps.not sure how that will help the op as that just adds the app to the home screen. it does not help the op get a popup message of a new text. plus this thread was started last year.....no reply from the op, so hopefully the issue got fixed.
... Now whenever I want to attach a file to anything it opens Drive....I made the terrible mistake of selecting a file in Google Drive to attach to a tweet. Now whenever I want to attach a file to anything it opens Drive. How can I restore the old behavior of opening Files on the local device?
Galaxy Tab S7 SM-T870, Android 13,
that is all fine and dandy, but what does your post have to do with the op which is about ringer volume going down? plus this thread is from 2019.I am a Computer Science major and a cell phone user since 1992, and a mobile phone user since 1982. I don't like smartphones any more and hate the tracking. I would be just as happy to go back to a satchel phone and do without all of the BS.
I'm not familiar with modifying Huawei phones, so can't say. But yes, it is possible that the update path for one model, or one firmware version of one model, doesn't go as high as for another. If you've been flashing firmware for one model onto a different model it's also not impossible that the official update process looks at your device and says "hang on, something's not right here" and refuses to install any further updates, though in that case I'd think it more likely that it would apply no updates at all than that it would update so far and no further.I upgraded the phone starting from WAS-LX1AC432B182 up to WAS-LX1AC432B210. Now it doesn't find new updates and I'm currently stuck with Android 7 and Emui 5.1.1.
Is it possible that the Warsaw-L21A C432B182 EU SERVICE is a special version for technical support and my phone and HiSuite can't find me the Android 8 update for this reason?
Well the "normal" thing that happens if you succeed in flashing a different model's firmware onto a phone is that the phone is hard-brickedEDIT:
Is it normal that the smartphone version has remained WAS-LX1A even using a WAS-L21A forced update firmware? It probably comes from the OEMinfo put.
.do you know how to develop android apps? have you worked with android studios?I want to develop an Pdf Scanner without any ads and without hidden costs for premium access. Is there any easy/quick method so as to not reinvent the wheel?
The best advice I can give you is leave the case off for a few days and hopefully it will correct itself, but something might be permanently bent.
I have seen the tight case issue come up a few times over the years going all the way back to Palm phones. Sometimes leaving the case off for a while corrects the problem, sometimes it doesn't.
Did you ever get am answer? I'm having the same issue.Hey Pixamark:
First off, great game!
I have an issue where certain games have been corrupted and cannot be cleared from "My Games." When I try to click on them, it says something like "Cannot find user slot" and there is no option to leave the game.
How can I clear these out? It is preventing me from playing multiple multiplayer games.
Thanks!
Oh you agree with me like this, I thought you talked with me all the time.Yeah yup, Same bro
