How to Change Default Voicemail To Audio
i barely use voicemail myself, so take that in mind with whatever i think up here
have you called your voicemail and gone through all of the settings there?
also, during one or more of my bloatware/google purges, i seem to remember an app or apps related to video voicemail.
perhaps you could use the Shizuku & Canta method to eliminate the app(s) altogether and leave your device no choice but to do your bidding
How To Delete Selected Cookies on Android Duck Duck & Firefox
i use duckduckgo as a search engine, but i hate their app.
its slow and clunky.
other than deleting certain but not individual cookies and other info, i dont know of any way to actally go into the actual app data and pick and choose what you want rid of.
some file managers allow me to view these files, but i dont know exactly what i am looking at and i cannot modify them because i am not rooted
even if i was, i still wouldnt know what i was looking at.
Phaseout of 3G Network
FM band modulation always swings the wattage up.
I used to talk alot of skip on the flat side of my beam. I used a 100 watt digital linear and on side-band and the flat side it would go a long way !
Yeah who would have thought that anything could replace that feeling .... And then came the internet !
Hy- Gain DSB, (double side band/upper and lower), with the clarifier modded to slide, as well as the dial up oscillator box, I could hit alot outside of the 27MHz band.
There was (and may still be) a CB magazine named S9. It had monthly listings of those caught exceeding the limits of radio boundaries set by the FCC.
I had a copy that had my name on the list, for years, but living like a gypsy it has gotten lost.
I had 2 agents from the FCC show up at my door one day and want to see my station .... Got me a 50 dollar fine for operating illegal power and operating on illegal frequencies ...
Lost the magazine but still have pics of the station. Oh and I still have my memories, but those are subject to retention, dependent on how much older I get !
That all was over 50 years ago !
laughinghard
install Windows 11 on a 10-year old PC — this method still works
I just installed Windows 11 on a 10-year old PC — this method still works
(Cut and Paste from another source/not my article)
rufus windows 11 hardware restrictions.
Gavin is the Segment Lead for the Technology Explained, Security, Internet, Streaming, and Entertainment verticals, former co-host on the Really Useful Podcast, and a frequent product reviewer. He has a degree in Contemporary Writing pillaged from the hills of Devon, more than a decade of professional writing experience, and his work has appeared on How-To Geek, Expert Reviews, Trusted Reviews, Online Tech Tips, and Help Desk Geek, among others. Gavin has attended CES, IFA, MWC, and other tech-trade shows to report directly from the floor, racking up hundreds of thousands of steps in the process. He's reviewed more headphones, earbuds, and mechanical keyboards than he cares to remember, and enjoys copious amounts of tea, board games, and football.
I'm still rocking Windows 10 on a number of devices around my home. It's not that I don't like Windows 11; it's more that I just don't always have the time to back up the hardware and make sure everything is compatible with Windows 11 hardware requirements.
That's in part because Microsoft tightened the rules around what hardware could run Windows 11, and it was a big step up from the more carefree approach to Windows 10. In fact, Windows 11 hardware requirements made so many folks so angry that they left Windows behind for good once Windows 10 was officially declared dead.
But if that's not an option and you need to stick with Windows, there is a better option. The free USB creator, Rufus, has built-in options that let Windows 11 ignore the hardware requirements, meaning you can upgrade your computer either way.
rufus windows 11 iso creation hardware restrictions.
Interestingly, Rufus doesn't change how Windows functions or how Windows itself works. You still end up with a "full" version of Windows 11 without any modifications. That's because Rufus modifies the installation package rather than the operating system, making some tweaks to how the installer works.
When you create a Windows 11 USB installer with Rufus, you can remove TPM 2.0, Secure Boot, RAM, and CPU checks. Under the hood, Rufus disables the compatibility checks built into the Windows installer. One key component is appraiserres.dll, a file used during setup to verify whether your PC meets Microsoft’s requirements. Rufus replaces or neutralizes this file, so the checks simply don’t run.
It can also inject registry entries (under HKEY_LOCAL_MACHINE\SYSTEM\Setup\LabConfig) that tell the installer to bypass TPM, Secure Boot, RAM, and CPU validation. Normally, you’d have to manually add these during setup using Command Prompt, but Rufus automates the process.
As said, this isn't the same as "cracking" Windows like the older days of stolen Windows installations and keygens. Microsoft's Windows 11 hardware requirements are enforced during installation, which is how Rufus' workaround lets Windows 11 run on unsupported hardware.
First up, head to Rufus and download the latest version of the app. Also note that the Windows 11 hardware bypass options don't appear until you press the Start button — they were a specific menu previously, but Rufus has changed this functionality.
  1. Select the USB device you're using for installation from the dropdown menu.
  2. Now, select the Windows 11 ISO file you previously downloaded.
  3. From here, Rufus should auto-populate most of the menus and options. The Partition Scheme should default to GPT, and the Target system should default to UEFI. You shouldn't need to toggle any other options.
  4. Next, press Start. Rufus will give you a warning that your drive will be wiped during the process.
  5. On the next screen, choose your Windows 11 restriction settings. I tend to stick with the default options, but you can adjust as you see fit. The only options you shouldn't disable in this situation are the "remove requirements," as that's what you're trying to achieve.
Then, you just have to sit back and wait for the installation to complete.
Before you attempt to upgrade a computer that doesn't fit Microsoft's specific hardware recommendations for Windows 11, I strongly advise you to take a whole system backup.
If the worst happens and you can't boot into Windows 11 or something else in the process breaks and locks you out, you'll at least have a whole system backup to reboot from and start again.
How do I know this is worth doing? This is what happened to me when I tried to use this workaround a few weeks back, and ended up staring at what looked like a dead PC. As I'm sure you'll agree, it's not a fun experience.
On Windows 10, it's surprisingly simple to back up your whole PC.
  1. Input backup in the Start menu search bar, and select the Best Match. Note that this uses the older, original Windows backup tool, which is more robust for this type of backup.
  2. Next, select where you want to store your backup. Don't choose the drive hosting your operating system, as that will get wiped during the Windows 11 upgrade. You can use an external hard drive with enough storage.
  3. Now, select Let me choose. From here, you can choose which files and folders to back up. I tend to back up the C: drive, as this is typically where the operating system is stored. Note that the Windows 11 installation process shouldn't do anything to your other drives—only the target drive for the operating system.
  4. Make sure the Include a system image of drives option is checked, then press Next.
  5. On the next screen, you can check the settings, then run the backup.
Depending on your drive size, this can take a significant amount of time.
upgrading windows 10 to windows 11.
There are two main ways to use the Windows 11 bootable USB drive. The first is to use it to upgrade to Windows 11 directly from Windows 10. This involves inserting the USB drive, letting it check for updates, and allowing the installation process to complete.
This process is simple and straightforward, and gives you the added option of choosing files and folders you want to keep. The other big difference is that the direct upgrade gives you the "Go back" recovery option, which allows you to revert the installation up to 10 days after upgrading. It's a handy additional backup option.
In fairness to Microsoft, its "upgrade in place" option has massively improved over the years. It's a much better prospect than when Windows 11 launched in late 2021, when the process was beset with errors, bugs, data loss, and more problems. I upgraded a laptop from Windows 10 to 11 using this method, and it hasn't had a problem. I also found an older laptop my kids were using had upgraded itself (go Windows?) and was also still working fine.
The other option is the more nuclear version, which is to use the bootable USB drive to make a clean Windows 11 installation. This option doesn't allow you to choose any files or folders to save during the process, but most experts agree that it's the better option as it reduces the chances of errors and other bugs after installation. However, there is no "easy rollback" process during a clean installation, as you're not using the existing Windows 10 files to upgrade. It's a completely new version of Windows.
It sounds like skirting Microsoft's Windows 11 requirements is some sort of underground hack, but in reality, it's just clever tinkering with the installation files. It's also great because it gives you a way to upgrade older machines still running Windows 10, meaning they can still receive important security and feature updates.
I'd really strongly advise you to take the full system backup before making any changes to Windows 10. Just because you can skip the requirements and upgrade to Windows 11 doesn't mean you shouldn't take adequate precautions when doing so.
Cataract Surgery
Interesting. I still have floaters after double cataract and lens replacement. Aren't floaters retinal?
I have no idea. I know I had floaters and a few days after each cataract surgery they were gone. This is the first I've seen of them since. I remember seeing floaters as a kid. I was fascinated by them and attempted to manipulate their movement with my mind.
Why does my Galaxy A13 keep switching off auto-rotate?
I swipe down to get to the quick settings (or whatever it's called), and no matter how many times I've set it to auto rotate the screen, it's switched back to either portrait or landscape lock a few minutes later. When it goes to landscape lock all on it's own, it's making a lot of stuff difficult as you'd expect. Is this a common issue?
Really moving the full screen around, and you turned it off? Moto actions and clear the data and cache, underneath apps.
Filter
