I really do not like it when, it saves your original photo and you are the person, who has it already saved. Seriously why not have just one copy?Yea, I tried it myself in the end and confirm that the drain wasn't noticeable. I turned the auto status off anyway because of the annoying notification you can't remove.
How Cloud Computing helps you in Education?
Do you mean strictly in terms of education, or in general, or what?What do you think of Cloud Computing.
To learn how to do that programmatically, your best bet is to post in our Android Development board. That's the place for all things related to creating apps.How to get imei number in android Q programatically
That's not a lot to go on: could be anything from your account running out of credit to a glitch in your provider's systems, your SIM having failed, you've fiddled with the "testing" menu and changed your radio interface settings, your phone's transceiver has broken, someone is using a cellphone jammer nearby, there's a civil emergency and civilian phone services have been disconnected(*),...Can't make phone calls
. Seriously though, we know nothing you don't tell us, and those 4 words allow a very wide range of possibilities.I'm no android expert, so please excuse the wordy and perhaps simplistic question ...
I have an old S5 running on Android Marshmallow (6.0.1) on which I have the call recording app, ACR. It works fantastically well, and I rely on it heavily for various reasons. I also stopped updating the app after notification from the developer that they were having to make changes due to Google's new security policy, and all was well in the world. Recently I managed to crack the screen on the S5 and, although it is still working and held together with a screen protector, I decided to get a new phone and went for the budget Samsung Galaxy A10 for a mere £140. Problem is, it runs on Pie (9) and call recording is almost totally restricted.
However, I watched this video -- (cued up for the relevant bit) and find that call recording is actually built into android, but deactivated in some regions due to Google's security policy (IDIOTS!). I haven't tried the app on the new device, but am assuming it will not work as the developers say it doesn't. So I am considering rooting the phone in the hope that this will allow me to change the settings and enable the android call recording feature within the phone itself.
I've never rooted a phone before and have heard warnings about it, so I have a few questions:
1. I know it will possibly void the warranty, but if I don't care about that, is rooting generally reasonably safe? Does the danger largely depend on what you do to the phone once it is rooted?
2. Is there a good step-by-step guide to rooting for the A10?
3. Is it definite that rooting will allow me to make changes to uncover and enable the stock call recording facility within the phone itself?
4. Is there anything else I should consider?!
Thanks in advance ...
The first part sounds like Rusty Lake.I need some help finding a game. That was on the app store when I was about like 14ish. So about almost 10 years ago.
It was a hidden object/Escape Room Game. It was 2D Cartooney. But it was kind of intense. Like it started off with being in an abandoned train station. And then you had to help your friend cross like a chasm. Once there, you continue to the next part of the story.
And you end up in like a dojo area
And then you kinda end up like in a room locked away. And you have to figure out a way out. And there is a picture on the wall that has what looks to be alchemical symbols.
Um...I'm not sure what you're asking...or if you are asking something.About API call from android
My guess is that he's using the AF app, which was discussed in this thread. It's a very annoying glitch!It's quite difficult to read your post, it's all full of "77;☺☺☺	"
