It could be a server side issue
nah, done it ever since i flashed as soon as it came out.
I can send u one if u need it
I dont see anything for dropping the CPU level down from 1.8....
Is Voltage Control app OK to use with stock roms?
Thanks LilBit!
When I posted that question, I should have added another. Is Battery Calibration app useful with stock rom? My indicator goes down slowly for the first half of the charge & seems to go down faster after half empty (allowing for variations in app usage). It may be all in my head. On a totally different note, the same thing happens with gas gauges in cars I've had... the first half of the tank gets higher gas mileage than the second half. Maybe it's just the way some gauges work, or maybe I hallucinate![]()
Battery Calibration works on stock rooted roms
If its not a lack of usb cables it my computer...
I know some of you remember when the hard drive on my laptop fried about a year ago when I was doing theme work... well my laptop stopped working againWindows doesn't wanna boot for me, and even System Restore and diagnostics and such are failing to repair the bad area in my system
for now I can use my desktop but I'll be spending EVEN LESS time until I can get my laptop repaired since its time for midterms at my school and I really need some things on my laptop; I can't graduate without it. I won't be getting on as much this week so I can fix it asap and jump back into rom work as well... so wish me luck
